[Tutorial] 2013 SuperCab Door Panel Removal - Ford Truck Enthusiasts Forums
Old 12-09-2012, 04:08 PM
Casey_78 Casey_78 is offline
Casey_78 is starting off with a positive reputation.
I figured I'd write up this brief description on how to remove the door panel on the Supercab F150 as I didn't really find a good description of this process. I did this on my 2013 but I imagine its similar if not the exact same for the 2009+.
First is to remove the single screw at the bottom of the door panel.
Next, remove the two screws on the side of the door panel. You can find them on the side that opens outward.
Next, remove the power window switch.
Next, remove the molding on either side of the window. It should just pop off, but I recommend using hard plastic tool sets that you can get from most hardware stores. 5 Piece Auto Trim and Molding Tool Set
You will need to remove the seatbelt before removing the molding behind it. Just pull on the plastic piece below the piece that says "pull", the one that says "pull" is to adjust the height of the seatbelt. The one you need to remove is just below it. You will need a star bit to remove the belt.
One screw on either side will need to be removed.
Finally, there are two screws in the door handle itself. Remove them and then remove the door handle form the door panel. You should be able to remove the door panel leaving the handle attached to the door.
Old 01-13-2015, 09:19 PM
GeneralGuttless GeneralGuttless is offline
GeneralGuttless is starting off with a positive reputation.
Thanks for the info
Don't know if you still access the site.
Just got a new to me 2011 F150 supercab.... just making it mine... couldn't handle the factory speakers... this helped.
Thanks
Old 01-01-2017, 02:26 PM
rbentnail rbentnail is offline
rbentnail is gaining momentum as a positive member of FTE.
Old post I know, but I had a horrible buzz/rattle in my 2013 rear left scab door and these were the best instructions I could find. I snapped a few pics as I stumbled along hoping to help the next guy/gal.
Quote:
6mm nutdriver/socket
Under little covers. Again 6mm nutdriver/socket
I skipped this step and unplugged the switch later, when the panel was off.
Left side first. Pulled and wiggle from the top. There's a hook/tab at the bottom you don't want to break.
Now the right side
T-50 TORX wrench.
Then pull/wiggle from the top.
One screw on either side of the window will need to be removed.
6 mm nutdriver/socket.
Remove the cover, then the screws. 10mm socket.
Kind of lift up on and wiggle the panel, it'll pop off towards you. It was here that I unplugged the window switch.
I popped the switch out before re-installation and fed the plug up thru the hole and snapped the switch in place afterwards.
Old 01-01-2017, 02:36 PM
Now, it's been rainy here for 2 days but imagine my surprise to find a wet speaker. Speaker mount screws take a 7/32" nutdriver. 6mm is too big, 5 mm too small.
All the little pieces of foam used for rattle isolators, the speaker, latch cables- all wet. I added some soft adhesive-backed foam to the inside & outside of the speaker as well as cutting a freezer bag and putting a "poncho" over the speaker inside the door when re-mounting. There were now puddles in the door. Time I guess for new weather sealant!
This last pic is the panel installed, you can see what I meant about "feed the window switch wire up thru". The window switch snaps back into place after plugging in.
I also noticed lots of "looseness" on the plastic panel against the door after I re-installed it. If the buzz/rattle comes back I might have to foam that too. We'll see.
Hope these pics help!
Old 01-03-2017, 08:01 AM
Robbgt's Avatar
Robbgt Robbgt is offline
Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.
Quote:
They sure do, and I need to do this soon. Thanks for the pics! Reps sent
1960 Ford F-100 Panel RIP 1948 F1dude 1957 - 1960 F100 & Larger F-Series Trucks 15 02-24-2015 08:04 PM
1995 Explorer ECM and Owners guide Yahiko All Other Items for Sale 3 01-30-2014 03:07 AM
Hutch's 1991 F250 build thread Hutch17 1987 - 1996 F150 & Larger F-Series Trucks 175 11-07-2013 10:25 AM
Where to removal metal to repair wheel arch?? tkisling Paint & Bodywork 23 08-26-2013 10:46 PM
Is Floor panel seam cut stock? checksix 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-23-2013 04:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
