No spark + "No Link" code
Hello all. 99 F-150, 185K miles, 4.2L 6 cylinder, Auto, 2WD.
Also posted in 6 cylinder engine forum.
Truck parked about 12 months but started and run regularly. Now no spark. Recent (within 10K miles) coil pack, wires and plugs. Pulled plug and appeared ok, minor soot and tan electrode. Sprayed starter fluid into throttle body... nothing. Not even a misfire or sputter.
fresher battery installed, Grounds all good. Checked fuses and all appear good.
Put cose scanner on and it says "No Link". Hmm. Once hefore this happened and it was a 20amp (yellow) fuse. but I never had no spark.
Motor turns over fine.
I know this is not a easy one, but can you help us get this going? ANY ideas are a help.
Like I said it always ran great; never had no spark.
Thank You
Thank You
99 4.2 PCM Power checks
Quick check for PCM power: Observe MIL at power on. If lit, the PCM is receiving power. Secondary check: Look for +5V at the TPS BRn/WT to TPS RED/GRY.
If no PCM power, check following:
CJB F30 - HOT in START/RUN - Required to energize PCM Power Relay
BJB F2 - Supplies power via NO PCM relays to following three fuses in the BJB:
F18 - PCM, MAF, IAC, injectors, energizes FP relay
F23 - Supplies power to various solenoids and upstream O2 heaters, IMRC, and cam sensor
F24 - downstream O2 heaters, auto transmission
blairsie
11-05-2018 05:41 PM
