Where to install tail gate LED light bar
I am installing this LED light bar on the rear of my 2012 SD: 60 Inch Full Size Truck Red LED Tailgate Light Bar
Installation instructions recommend removing the tailgate and installing the light bar on the lip below the gate. The lip is a rough textured panel inset deeper into the truck by say 2 inches (that rough texture might be the factory truck bed spray in liner?).Also, there is a bracket under the tailgate on the right side that interferes with the light bar.
Has anyone else run into this question? I am wondering if I should mount the light bar on the exterior of the tailgate itself (just below the Super Duty signage).
I'd rather not drill and screw into the tailgate, though.
Thanks for any suggestions.
Thank you, Sammy
This link has a discussion about my bracket (and I should have referred to it before ordering my light bar!): https://www.ford-trucks.com/forums/9...-question.html
If you want to put it ON the bottom of the tail gate you could use the 3M tape
that stuff does not like to come off and needs to be heated to apply/remove.
Clean the place where you are going to stick it with wax and grease remover
and then clean off any residue before you try to stick it on.
I wished I could recall the name of the stuff. It was used to put on my aluminum
diamond plate bed caps. They never moved even after all the just I bounced off them.
Sean
Sean
Thank you, Sean - there a variety of 3M tapes, and I even have some left over from another project. You are right; the tape can be tenacious, which is good in this case.
I have an email into the mfg. of the light bar and will see what they have to say.
I really like the backup light capability on this bar.
There is a link earlier in my thread that will take you to some pics. Not very clear, though.
The bracket is under the tailget on the right side - right in the way of your light bar (and mine).
I need to remove the tail gate and see what that bracket is for; I've heard it's just a rest for use when removing the gate. We'll see.
If you absolutely must drill new holes, you will have to remove your tailgate(not a big deal) It would also make life a lot easier for you with the install.
Magnus E
11-13-2014 07:08 AM
