Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 12-08-2012, 06:29 PM
jjurva! jjurva! is offline
Garage is empty, add now
jjurva! is starting off with a positive reputation.
Axles
The axle on my truck, 1960 f100 4x4, snapped to the right of the differential. I welded it together so i could move it around my yard and needless to say I need a new axle. I found a 59 f100 i could buy for relatively cheap. Can I pull the third member and put my gears into the new axle from the new truck and put that on my truck?
  #2 (permalink)
Old 12-08-2012, 07:31 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
If you are talking about "an axel shaft", that broke, why not just swap one from the '59 and save yourself a lot of work. If you are talking about "an axel housing", the hollow tube which the axel goes into, in answer to your question, yes!
  #3 (permalink)
Old 12-08-2012, 09:21 PM
The housing broke. The shafts and gears are fine. Thanks! I looked at it today and when I got there I wasn't sure what to look for. The housing looked similar but I just didn't know if it would work. I can finally get my truck back on the road! Also the new axle housing has spring welded to it. Is this a problem? Can I just grind them off?
  #4 (permalink)
Old 12-08-2012, 10:19 PM
GB SISSON's Avatar
GB SISSON GB SISSON is online now
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Whaaaat? Just don't reuse the springs!. Welding the springs to the rear axles? Suddenly I don't feel like such a hack.......
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #5 (permalink)
Old 12-08-2012, 10:38 PM
I was a little surprised to see someone had done that. They didn't weld the leaf springs to the truck but to the inside of the leaf spring they have a regular helix spring welded from the axle housing to the chassis.
Tags
1960, axle, f100, gears
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
