Broken timing chain - Ford Truck Enthusiasts Forums
Broken timing chain
Old 12-08-2012, 07:25 PM
hmcox1017 hmcox1017 is offline
hmcox1017 is starting off with a positive reputation.
Broken timing chain
I am the owner of a 2000 Lincoln Navigator with a 5.4l v32 intech v8 engine. My truck cut off in the street and stopped running one day and hasn't cranked since. I removed the valve and timing chain cover and discovered that the timing chain is broke. Is there anyone out there who could tell me how to uninstall the broken timing chain and then reinstall a new timing chain? Actually, there are two timing chains. Any help would be greatly appreciated!
Old 12-09-2012, 06:32 AM
critterf1's Avatar
critterf1 critterf1 is offline
critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.critterf1 has a good reputation on FTE.
You have more problems than just a broken chain.
Old 12-09-2012, 07:29 AM
LMS Residential's Avatar
LMS Residential LMS Residential is offline
LMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputationLMS Residential has a superb reputation
Your 5.4 is an interference engine. When the timing chain(s) break, the piston to valve clearance is such that major internal engine damage likely occured. Time to rebuild or replace. How many miles are on the truck?
Old 12-09-2012, 07:51 AM
Broken timing chain
I have a little over 180,000 miles on the lincoln navigator. Also, I really appreciate your extra advice. Thanks!
Timing Chain brent1204 Ranger & B-Series 3 07-06-2015 09:18 PM
Timing chain scorpion58 1997 - 2003 F150 2 06-13-2015 11:13 AM
Timing chain and tensioner kewing75 2004 - 2008 F150 1 02-28-2014 11:10 PM
timing chain. broken guide? when to replace? phillycincykid 1999 to 2016 Super Duty 9 01-06-2014 09:26 PM
4.6L 2V Upgraded timing chain kit parts RRousta Explorer, Sport Trac, Mountaineer & Aviator 6 11-20-2012 01:13 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
