Cab Water Leak
#31
#33
Just under the evaporator core housing. Its a little nub sticking out from the firewall with a fairly big hole in it. Anyone have a good reference on dash removal. Im in the middle of removing it and I can't seem to find all the bolts. I have the passenger side completely loose and ready to go. Something on the drivers side is keeping it in. Im trying to take the vents and dash as one piece. I know it can be done, just cant seem to find the last bolt. Does the steering column bracket and parking brake Have to come out first?
#35
Bingo! Pulled the blower motor out and the chamber where the blend door is is wet. The foam around the door is wet. Then I went in the cab and checked this vent. It has standing water in it.
This is the far right side of the firewall, next to the passenger side kick panel.
Vacuum actuator switches just fine though... It is fairly difficult to change the temperature setting.
#38
Another leak I found was with cab lights, not so much the OE, the aftermarket junk LMC ones. Then one day I washed the truck and from the bay I went into the dryer, bye bye went 2 of the clear covers . Now my ford has mopar clear cab lights . LED 3rd brake lights always seem to get moisture in them also I went through and sealed it before putting it on.
Curtis
Curtis
#39
Evan, looks like you and I have the same leak. Gonna do the same thing here soon. Also getting ready to do the mass air conversion and am thinking about tearing everything apart from the firewall fwd just to go through it. I know for a fact that my seam sealer under the cowl is in horrible shape, so that's one thing that has to happen, just thinking I might go all the way since its not my DD.
It kinda sucks here in VA. In order to have a vehicle in your driveway it has to be licensed, registered, and insured. Uggg. So now that I have that done I can start what I originally purchased the truck for, a project. lol
#42
Thanks Brad, will check that too, but with 254+++ on the truck its got a LOT of little things (and some major) that need attention. PO was a good guy that always had things fixed, but not too much on maintenance unless he could pull it into a shop and pull it out when it was done, and some of the mechs were not all that caring if ya know what I mean.
Sorry Evan, will get out now.
#43
Hi Evan,
My truck was leaking when I first got it. I tracked it down to a chip in the paint on the roof right where two pieces of metal had been welded together. It was only an inch or two away from the top of the windshield and near the top left side. There was a small gap in the weld that allowed water to get in and flow around the window seal on the inside before it ran onto the carpet. I never could find the leak until I was driving the truck in severe rain and enough water came through that it started to drip. I sealed it with a clear epoxy. It hasn't leaked for about two years now. However the body man is going to shoot me when it's time to paint my truck
#44
Thanks for the suggestions guys. I have just been too busy to do anything about it. I know the leak is somewhere in the heater box. It isn't the heater core either, I checked that. Cab lights can't be it either as it leaked before the truck had them. And nobody worry about jig jacking a thread, it here to any and all that need it.
#45
