1999 F-450 with Fontaine bed and AIR BAGS
Driving down the road I stopped at a stop light. I heard a big click and the motor died. Moreover, the red light on the dashboard went on, showing that the suspension air bags were deflating. This was a week ago, and I have not been able to get the air bags pumped up again.
Can anyone help? Is it a fuse? If so, where is it?
We pull our 38 foot 5th wheel with this truck so we need the air bags working. We do not know who might work on this particular problem.
We are newbies concerning fixing the air bags and other mechanical difficulties. Along with this I have chemo brain, so haven't been able to think what to do.
Thanks,
Keith
Thanks,
Keith
Sounds like something broke and possibly cut an air line. The Fontaine package is aftermarket so there probably isn't very much documentation available for troubleshooting.
You probably want to inspect the engine, transmission and drive line for any obvious signs of damage. I presume you have an onboard compressor so check that as well. If it's engine driven then you may have a problem with the drive belt. If you have a diesel engine, then it's possible that you may have an engine driven air pump mounted in the 2nd alternator location (although this is not very common....). Here is a photo showing both alternators. The secondary location is down low on the passenger (right) side.
Does your truck start and drive OK now?
Thanks for your response, Shake-N-Bake...
Truck drives fine, accept for the bed bouncing and making noises like it is going to break.
My wife and I are full-time Workampers, not very wealthy, got to work till we die — need to know what we can so we are not overcharged when taking our rig in to be fixed.
Thanks again,
Keith
Thanks again,
Keith
audichopper
1997-2006 Expedition & Navigator
15
06-12-2017 10:03 AM
Oldmanwntr13
17
05-22-2016 06:29 PM
jonf
08-28-2014 07:32 PM
