Gasket Compound and RTV
Okay, I'm in the rebuilding stage and want to clarify when to use gasket compound (I'm using the copper stuff) and RTV.
Right at this moment I'm wondering if I need compound or rtv for the oil pump?
But beyond that, is there a general rule on when to use these?
I think the copper stuff says not to apply to rubber, so do I use RTV on rubber?
I assume you mean copper coat? Sprays out of a can?
If so, the only place I generally use copper coat is on head gaskets, the block where the gasket goes and on the heads where the gasket goes. It isn't a requirement to even use it at all, I use it to fill small imperfections and as cheap insurance. It appears your block has been surfaced so it would be an optional thing for you.
I have also used it on exhaust manifolds and gaskets, once again, just to fill small imperfections.
I would not put any sealer on the oil pump at all. I never have, and I've never had an issue, just the gasket itself. You do not want to take the chance on something blocking an oil passage or getting into a bearing.
Opinions vary on silicone/rtv. Rubber shouldn't need any, only on the corners where it meets another gasket, or if two different assemblies meet its a good idea to put some there. I use silicone very sparingly, a very thin layer is good for flat surfaces and a small line for joints.
I find Ford gasket glue to be very handy. Its similar to contact cement. I generally use it to glue one side of a gasket on to the smaller part, and a thin layer of silicon on the other side where it will meet the block, or larger assembly - if the gasket is cork.
I also find it handy to drop the bolts in backwards to hold the gasket in place until the glue sets up, you can also do this with silicone of course. That way you know you have all the bolts and they will go through the holes.
If the gasket is rubber I may use a little glue to hold the gasket in place or not depending on how hard it is to get the assembly in place.
-Water pump gasket(paper) Permatex Aviation Gasket Cement
Timing cover(paper) Permatex Aviation Gasket Cement
-Valve cover gaskets(rubber) Go on DRY
-Oil pan gasket(rubber) Go on dry, except in the corners where the block meets the front and rear main. Small blobs of RTV in the corners
-Oil pump(paper gasket)Permatex Aviation Gasket Cement
-Head gaskets DRY DRY DRY DRY DRY DRY DRY DRY DRY
-Intake gaskets Dry or Permatex Aviation Gasket Cement and a 1/4" bead of RTV where the intake meets the block and where the head meets the block(throw the rubber things in the trash where they belong)
Schuyles
03-30-2012 05:47 AM
wdhille
09-09-2009 07:32 PM
jenkinsj
11-26-2005 07:33 AM
