No spark & scanner says "no link"
Old 12-09-2012, 02:23 PM
hendedo's Avatar
hendedo
hendedo is offline
Hello all. 99 F-150 4.2L, Auto, 185K miles, 2WD
Truck has been parked for about 12 months. Started regularly and has never given a sign of real trouble. Now, it has no spark.
Recent (within 10K miles) coil pack, Morotcraft plugs, Motorcraft wires. Plugs look good, not too sooty and electrode is tan. Engine turns over fine. Plug going into coil pack has power on the forward wire when key is on. But none of the other 3 wires have power when cranking or static.
Sprayed starter fluid into throttle body; Nothing. I expected it to at least fire/backfire, spit, cough...something.
Looked at fuses and all appeared good. Is a relay in the box under the hood that has a crack in the black plastic housing; not sure if thats it.
Put my scanner in and it read "no Link" Saw this once before and I had a bad 20 amp (yellow) fuse. But they are all ok.
I know this is a tough one but where do I start? Thank You for thinking on this one.
RossTheBoss
Aerostar
05-08-2018 06:10 PM
hendedo
1997 - 2003 F150
12-11-2012 05:24 AM
copuntryboy
1997 - 2003 F150
04-20-2012 10:32 PM
99b3000
1983 - 2012 Ranger & B-Series
09-05-2010 03:10 PM
JMKiser
Modular V8 (4.6L, 5.4L)
05-08-2008 10:08 PM
Quick Reply: No spark & scanner says "no link"
