Alternator with external regulator
Old 12-07-2012, 12:27 AM
Hansolo99's Avatar
Hansolo99
Hansolo99 is offline
Ok I bought a 1963 econoline and when I got it the seller told me that the regulator light has been on for some time and needed to be addressed. I went and bought a new regulator but soon learned after looking that I have a alternator not a generator. I am pretty sure I don't need the external regulator since the alternator should have it built in already. So how do I bypass the regulator?
I will take some pics tomorrow and I really hope someone can help me out? PLEASE..................
Old 12-16-2012, 07:59 PM
EmilBarnabas's Avatar
EmilBarnabas
EmilBarnabas is offline
A 1963 Econoline came stock with a generator, not an alternator.
Someone might have replaced the generator with an alternator. If so, they should have gotten the regulator that goes with that alternator. The generator regulator is not designed to work with the alternator.
Also, I remember that you have to put a resistor across the generator light when you replace the generator with a alternator. I don't remember what size. That might be why your light is on.
There are modern one-wire alternators that have an internal regulator, which eliminates the extra wiring associated with an external regulator. There is some debate as to wether these work better or worse than the ones with the external regulators.
Old 01-12-2013, 10:04 PM
Flhr4life's Avatar
Flhr4life
Flhr4life is offline
alt light bypass
I have a 1981 ford van, new alt and volt. reg there is a problem withdash cluster and i need to by pass alt light to move this van. how do i do it
Old 01-20-2013, 08:14 AM
Redtires019's Avatar
Redtires019
Redtires019 is offline
On whether you need the regulator or not depends on what alternator is used. Older Ford Alternators used an external regulator. If this is an older modification then it may have a Ford alternator with the external regulator. You can either replace it with a 1 wire alternator, or buy a regulator for a 1965+ vehicle with an alternator ( 1965 was the change year for most Fords).
Old 05-19-2014, 08:59 AM
zombievan1966's Avatar
zombievan1966
zombievan1966 is offline
fyi.. i just replaced my regulator on my 66 with a 240 l6. i looked for an internally regulated alt but the 15$ regulator was cheaper than a 65$ alternator.and its faster to replace the reg than the alt.
packrat56
15
09-28-2014 10:16 PM
RANGER589
05-20-2011 08:40 AM
sciondude09
03-15-2009 05:59 AM
79 E350 rescue
Electrical Systems/Wiring
05-09-2006 06:37 PM
Quick Reply: Alternator with external regulator
