Power steering gear hits shock mount
Hi guys i have been mocking up some parts before i paint my frame and i have a few questions. I am upgrading may 66 to power steering and disc brakes. I mounted the power steering gear and it hits the spring mount on the drivers side. Its not completly tight i think if i put a washer in it will be ok.
One other thing is i am mounting the poportioning valve on the front cross member were it was on the donor truck. There is one hole there i just need to drill for the other one. I was wondering if the valve has to be level like i have it in the picture. I forgot to take a picture before i took it off of the donor truck
And last here is a picture of the susspention parts i have painted so far.
I just mounted my proportioning valve on the cross member like my donor, reused one hole and drilled one new one that way I could reuse some of the brake lines and have an easier time using the old lines as patterns to fab new ones, not sure if it needs to be level or not but I would think in a closed hydraulic system the valve wouldn't know the difference.
kazuya2416
24
02-25-2019 11:46 AM
kurtnelson
12-30-2018 06:26 PM
Indybeer
12-11-2017 01:57 PM
hotrodbob51
02-15-2011 06:51 AM
