Planning a gear swap and have a few questions.
Ok My current 95 f150 4x4 e4od 351 with 3:55 gears on 33x12.5-15 tires isn't too bad driving around with just empty truck. But as soon as I put any trailer behind it it is a DOG. I just picked up a 2500lb tent trailer and couldn't hold 100lm without down shifting. I hauled a 14' enclosed trailer with my Polaris rzr inside and managed to get 8 mpg lol and had a hard time on a couple hills.
So that leads me to wanting to do a gear swap. I'm thinking il like to go 4:56 that way it gives me the option to go to 35" tires when the time comes to replace the current ones.
I'm have read I need to get a larger carrier for the front TTB to be able to go to 4:56. Is this right? If so is there something you guys can recommend? Or is there a vehicle to keep an eye out for that will have the carrier I would need?
Also any suggestions on what gears to get?
Thanks in advance
Thanks in advance
How bad will the 4:56 be on the hwy with the 33's?
I will be pulling a 2500lb tent trailer and have my 1000lb rzr on the back of the truck. My thought is I don't think the gearing will make it any harder on gas when loaded... Or should I just keep the 3:55 and suck it up the few times a year I'll be pulling the trailer? (is it going to be worth the time and money to do the swap)It doesn't have an issue with just the rzr on the truck, will hold hwy speeds no issues. It's just when I put the trailer behind it
With the run around I'm getting trying to get motor mounts from them I dOnt think umm be buying from them anymore. Been 2 months and now the third time tryin to get them sent to My house. First 2 times were returned o sender for incomplete addresses.
i found them on rockauto.com but im not sure how big to go, doesnt look like they have anything over 33.. and im not to good with gearing etc. so i have no clue what to look for... biggest it has on there is 32
