1995 Ford F250 351 4WD Under Hood Fuse Box Diagram - Ford Truck Enthusiasts Forums
Old 12-06-2012, 04:25 PM
andrewcollins2 andrewcollins2 is offline
andrewcollins2 is starting off with a positive reputation.
My truck did not come with the diagram that shows what the fuses are for in the black box under the hood. Does anybody have any idea what fuses and relays go to where on a 1995 f250?
Old 12-06-2012, 06:16 PM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Sorry for some reason I can not post a link to a photo.
Old 12-07-2012, 09:15 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
This should work for you:
Old 06-19-2013, 06:35 AM
TateF250's Avatar
TateF250 TateF250 is offline
TateF250 is starting off with a positive reputation.
Thanks a lot for posting this, I don't have a book so this is really handy!
Old 06-19-2013, 11:50 AM
rla2005's Avatar
Glad to see we could help you out.
Old 02-08-2014, 10:18 AM
BakersF-250 BakersF-250 is offline
BakersF-250 is starting off with a positive reputation.
Exclamation Fuel Pump won't juice!
Hey guys,
Ive been havin a helluva time diagnosing why my fuel pump on my 97 F-250 HD gas will not work. The truck came with two tanks, but I eliminated the front tank 3 years ago (rotted and leaking), and replaced the rear tank/pump at the same time. Started by assuming, on bad advice, to replace the rear fuel pump yesterday.
Well, long story short, it still doesnt work. I then replaced the relay, but am still just getting a click instead of a humm, when cycling the key. Ive double checked the inertial switch on the passenger side kick panel, and thats depressed.
I figured I'd attach this post to this thread seeing as it was already discussing the fuse box in the engine compartment. Any ideas on where to go from here and how to properly test the relay box and fuel pump harness?
Any thoughts are greatly appreciated
REW
Old 02-08-2014, 10:37 AM
subford's Avatar
First of all I take it you have an OBD-I EEC-IV system.
If so just ground pin #6 of the self-test plug, turn on the key and see if the fuel pumps run.
If they do not then go to the inertial switch on the passenger side kick panel and check for voltage with a load type test light. A volt meter will not work here as it will say there is voltage when there is not.
If the fuel pump do run when you ground pin #6 of the self-test plug and turn on the key you may have a bad PCM Computer. But short pin #2 to pin #6 of the of the self-test plug, turn on the key and see if the fuel pumps still run.
If they do not then you have a ground problem coming from the body ground to pin #40 & #60 of the PCM Computer.
Old 08-26-2016, 01:39 PM
pjtn pjtn is offline
pjtn is starting off with a positive reputation.
Hello - what are the two wires that come out of the outboard end of the engine compartment fuse box? and on different subject - the fuel injectors are marked positive on one side- does the positive go to the red wires or the white pin 59 or tan pin 58?
Old 08-26-2016, 05:03 PM
rla2005's Avatar
Quote:
No idea...pictures please.
The positive side of the injector goes to the red wire (supply). The negative side is pulsed to ground via the computer to turn it on/off.
It would help to know what year/model/engine/transmission truck you are working on.
Welcome to FTE!
Old 08-26-2016, 05:32 PM
Welcome to FTE!
Thanks so much - big help on the injector question.
Manual transmission
Old 08-26-2016, 06:55 PM
subford's Avatar
The yellow wire is the power to the fuse relay box.
Any other wires are not stock and have been added.
Old 08-26-2016, 08:34 PM
great thanks for the quick replies- truck is running great now with wire repair to fuel injectors
Old 08-28-2016, 05:13 PM
Updated
Well - it ran great for two days - even passed smog check - but seems to have fried ignition coil - which was replace last week due to no spark. Is there a good trouble shooting tree or existing thread for this symptom ?
Old 08-28-2016, 05:54 PM
subford's Avatar
How do you know it has a fried ignition coil?
Maybe you have a bad PIP sensor.
Old 08-28-2016, 06:17 PM
No spark last week so replaced ignition coil ( very hot to touch) and truck ran for two days - would be happy to check PIP -looking for info
Under Hood Lamp No Power zimerman 1999 to 2016 Super Duty 2 02-18-2016 12:10 PM
Fuse box diagram amilcar 1999 to 2016 Super Duty 4 12-27-2011 08:52 AM
1995 f150 relay box street131 1987 - 1996 F150 & Larger F-Series Trucks 5 03-14-2011 04:25 PM
1995 ford f250 fuse box diagram Jeff and Nicolle 1987 - 1996 F150 & Larger F-Series Trucks 5 01-13-2011 09:08 PM
Fuse diagram BURNSTOUGHFORD 1987 - 1996 F150 & Larger F-Series Trucks 0 11-20-2009 12:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
