Vacuum Pump or Booster??
2005 E350 6.0 PS, hard pedal. Vacuum at check valve is 19 in hg, no sound. Put check valve back in booster, hardly any vacuum, sounds like I'm making popcorn! Vacuum is over 20 directly in the pump tube. Which is to be replaced, the pump or the booster, or both? Find it hard to believe both would go out together. No fluid is in the lines. Just quit.
Get one of the OEM/Liquid siphoning vacuum pump kit (25136) | Vacuum Pump Brake Bleed Kit | AutoZone.com
at Autozone. It's a vacuum pump kit and then put an adaptor on it so you can put the
booster under a vacuum and see if it is leaking. Also check the grommet on the booster
and see if it is getting brittle and that can also be a leak point. Last thing to check
under the master cylinder is the pushrod seals. The booster should hold a vacuum
for a short time.You can also put the hand pump in the line to the engine pump
with the check valve removed and see if it will hold a vacuum. Last see if the
check valve is leaking.
Let us know how this all goes.
Sean
Sean
I'd be a rich man if I were to have gotten a dollar for each one of these I have replaced on an E-350 for the exact concern you describe. Notice I say E-350 and not E-450. And that's because on E-450 applications a hydroboost is used for brake assist, while the vacuum pump is dedicated exclusively to providing vacuum to control the mode selection for the HVAC, therefore much less demand on the pump.
Sean
Sean
moroza
07-02-2019 12:59 AM
SNOWR8R
05-04-2017 05:12 PM
garrettsr5
35
07-10-2013 10:15 PM
mark vanford
01-15-2011 06:05 PM
