I'm making a few of the heating plates b/f Xmas. A PM works well.
Now I use a long radius elbow in place of the galvanized pipe fitting. I also weld hose bibs to the end of the tubes. It comes with a gasket. I should also note that the tubes no longer spread away from each other at suck an angle. I had to move them closer together so they would fit in the proper mailing box. It is finished with gloss black high temp paint.
I also have these stud kits, grade 8, with crimp nut and washers.
I don't have photos of one mounted. It is for the underside of an Offenhauser intake. When mounted the two hose fittings are pointing toward the right front tire.
In the photo below you can see one of the hoses connected to one of the tubes of the plate.
