Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Nite, Nascar & Other Limited Edition Ford Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-06-2012, 09:35 AM
1998Nascar 1998Nascar is offline
1998 Ford F-150
1998Nascar is starting off with a positive reputation.
1998 NASCAR Alignment
Many shops claim (including many Ford dealers) that the alignment specifications for the NASCAR are the same as a regular F150. After getting a factory manual, I found that they are quite different. The following are the alignment specifications for the NASCAR straight from the 1998 Ford Truck Service Manual CD -
Alignment Specifications - F-150 NASCAR 4x2
LH - Caster - 7.3 +/- 1.0
LH - Camber - -0.3 +/- 0.7
LH - Toe ---- 0.03 +/- 0.15
Total/Split (LH & RH) - Caster - -0.8 +/- 0.7
Total/Split (LH & RH) - Camber - 0 +/- 0.7
Total/Split (LH & RH) - Toe - 0.06 +/- 0.25
RH - Caster - 7.8 +/- 1.0
RH - Camber - -0.3 +/- 0.7
RH - Toe ---- 0.03 +/- 0.15
No, that is NOT a typo on the left & right caster, they ARE different.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
