97 F250 7.5 4R100
If that's true, that would be the first I've ever heard of. But I will not say that it's impossible that you have that tranny.
I just did a little bit of research, and from what I can tell, the 4r100 was first used in 1999 to replace the E40D as a heavy duty transmission. I didn't find one instance of it being in an OBS ford behind a 460. Perhaps crawl under the truck and take some pictures? I'm sure somebody would instantly be able to tell you what you have that way.
The main point here is the E4OD cannot be substituted for a 4R100 or vice versa. They are different enough to warrant an individual model designation. Whomever looked up the truck build info made an error with the reference to a 4R100 transmission. I have been wrong in the past from time to time, but to the best of my knowledge and documentation the truck should have an E4OD transmission.
I think I believe multiple people the same thing to me more then a piece of paper. I'll post some photo to settle any curiosity.
What's happening is I'm getting harder or sharp shifts especially 2nd to 3rd when accelerating hard - like 3000 to 4000 rpms. Most of the time it seems fine but in those cases it seems to hard. Had fluid exchange done at the ford store a year or so ago (maybe 5000 miles) and don't remember it doing it back then. I have a filter and 9 qrts of mercron v - I'll try that this weekend. Also it did seem to get better when I cleaned my pcv valve and fix the hose connected to it "I think"
Likely what's happened is when the build sheet was made up there was some confusion due to the new f150-based F250 in '97 along side the '97 OBS F250 heavy duty. The OBS F250 HD was the same as the '92+ trucks and would be available with a 7.5L and E4OD. The new '97 F250 would have been available with a 5.4l and the 4r100 which is an updated E4OD. Now MAYBE there's a 4r100 in there but as you've read it would be as-yet unheard of to anyone here.
Let's just pile on a bit more on this subject...the build sheet for my 2004 Excursion lists this:
Primary Features
Build Date: 24.10.2003
Vehicle Line: EXCURSION
Body Style: 4 Door Wagon
Series: 250 Series
Engine: 6.8L SOHC EFI NA V10 Gas
Transmission: E4OD(4R100)
Drive: LHD 4WD (PTD)
Axle Ratio: 4.30
Emission: 50 State Emission Requirements
Air Conditioning: Automatic Air Conditioning
Paint: Ebony (Solid C/C)
Primary Features
Series: 250 Series
Axle Ratio: 4.30
badasssapper67
25
05-12-2016 06:01 PM
Towtruckmike
11-04-2005 06:58 AM
MAHinton
01-23-2002 07:33 AM
