Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 12-05-2012, 10:40 PM
idt-572's Avatar
idt-572 idt-572 is offline
Garage is empty, add now
idt-572 is starting off with a positive reputation.
Sad day for my 2002 lightning, need block
I now have a picture window in the side of the block
Powdered metal rod left the seen. It had well over 100000 miles and hard ones to boot. Pulleys, cold air, programmer, enough to run 8.30 flat through the 1/8th mile.
I am going to build back with good rods and pistons but I will need a block, if anyone close has one, (I,m in middle Tn.) I would appreciate knowing about it.
I am thinking about adding the TFS aftermarket heads too if mine are damaged.
Curious if any one on here has any time with the TFS head.
__________________
Blake
1997 F-250 4X4 CC short bed, 3" dp 4" exhaust, TW 6 POS tunes from swamps, stage one injectors, Tymar filter, swapped out 4.10 gears for 3.55's, 900 ft lb South Bend single disc clutch, next mod is a 6.0 I/C. 1986 notch back mustang 580 inch 1003 hp @ 7200 rpm, 8.50 1/4 mile 156 mph 3060 lb. with driver.
  #2 (permalink)
Old 12-13-2012, 08:10 PM
ratrace2 ratrace2 is offline
ratrace2 is starting off with a positive reputation.
I'll light a candle for the little truck.
  #3 (permalink)
Old 12-14-2012, 07:15 PM
idt-572's Avatar
Thanks brother that means alot................. It was a sad day.
__________________
Blake
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
