Married/Divorced?
Old 05-23-2003, 09:59 PM
Ford Fan's Avatar
Ford Fan
Ford Fan is offline
Married/Divorced?
Basic dumb question:
Whats the difference in married /divorced transfer cases?
Is one better than the other?
Thanks!
Rusty is a traitor.
Old 05-23-2003, 10:10 PM
ecarter50's Avatar
ecarter50
ecarter50 is offline
Married/Divorced?
Married - trans is bolted directly to transfercase.
Divorced - there is a short driveshaft from trans to transfercase.
Old 05-23-2003, 10:35 PM
bronco351's Avatar
bronco351
bronco351 is offline
Married/Divorced?
Well, the MARRIED transfer case is bolted directly to the transmission. There are TWO drive shafts one from the Transfer case to the Rear axle. ALso there is one from the transfer case to the Front axle.
Now the DIVORCED transfer case has a short driveshaft from the Tranny to the Transfer case. Also it has the other two driveshafts from the tranny to both front and rear axles.
In my opinion a MARRIED transfer case is MUCH MUCH stronger than a divorced transfer case. The reason for this is there are less driveshafts (less things to break). Also Most divorced transfer cases run much warmer due to the transfer case using it's own fluid instead of sucking it from the tranny!!!
HOPE THIS HELPS SOME!!
Old 05-24-2003, 12:30 AM
77'F-150Mudder's Avatar
77'F-150Mudder
77'F-150Mudder is offline
Married/Divorced?
Originally posted by bronco351 In my opinion a MARRIED transfer case is MUCH MUCH stronger than a divorced transfer case. The reason for this is there are less driveshafts (less things to break).
I completely agree with that statement.
Originally posted by bronco351 Also Most divorced transfer cases run much warmer due to the transfer case using it's own fluid instead of sucking it from the tranny!!!
Dunno about that statement. If your transfer case is pulling fluid from the tranny you have a problem, especially if you're running an automatic. I've had to help a buddy more than once pull his NP205 on his 70' *cough* Chevy *cough* 3/4 ton due to bad mid seals in the t-case. It's a dead give away when you check your t-case fluid level and a couple quarts of gear oil comes shootin out.
Old 05-24-2003, 03:27 AM
bronco351's Avatar
bronco351
Married/Divorced?
Yeah, in the earlier FORD trucks the transfer case and tranny both share the same fluid. They both use tranny fluid.
Old 05-24-2003, 07:25 AM
gregdatech's Avatar
gregdatech
gregdatech is offline
Married/Divorced?
Divorced transfer cases offer the advantage of using whatever transmission combo you want. Dont have to use only a 4wd tranny. Allows more options
Old 02-21-2014, 09:10 PM
infinite-foamies's Avatar
infinite-foamies
infinite-foamies is offline
I see this is a dead thread, but transfer cases don't like to use gear oil?
chukar
04-25-2017 11:17 PM
chukar
03-20-2017 03:34 PM
kalebc2
03-17-2017 11:08 AM
chukar
11-27-2016 07:29 PM
chrono4
Offroad & 4x4
62
03-16-2006 09:40 AM
Quick Reply: Married/Divorced?
