engine swap - Ford Truck Enthusiasts Forums
engine swap
Old 12-05-2012, 08:00 PM
julie 54 julie 54 is offline
julie 54 is starting off with a positive reputation.
engine swap
I'm thinkin of swapping my 239 for a 292 my question is will my 1954 4 spd and bellhousing work with a 1964 292 3spd? I assume it will but we all know what assuming does! lol Thanks Julie
Old 12-06-2012, 04:16 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
While the bellhousing will swap between the engines, it will not swap between the transmissions. You will need a 3 speed bellhousing to use a 3 speed.
Old 12-08-2012, 12:00 AM
thanks charlie info appreciated
292 3spd Bellhousing Rockydm 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 02-04-2015 03:18 PM
T98 4spd swap? Gregxlt 1957 - 1960 F100 & Larger F-Series Trucks 15 02-20-2014 07:29 PM
ford 5 spd tremec behind a 292 y block??? mikhett Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 5 02-17-2014 11:49 PM
292 y-block to 262 inline 6 swap 64 f100 killerkjn Engine Swaps 1 12-09-2007 09:58 AM
292 to 302 red59 Engine Swaps 3 05-11-2004 12:16 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
