70 F100 steering column - Ford Truck Enthusiasts Forums
Old 12-05-2012, 04:14 PM
burdenweaver burdenweaver is offline
burdenweaver is starting off with a positive reputation.
My trucks steering column is way too long. When I sit in the seat I would like it to be further away. There stearing wheel is way too close for me. Is there a way to shorten it? Can this even be done?
Old 12-05-2012, 05:07 PM
willowbilly3 willowbilly3 is offline
willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.
Look under the dash where it bolts on, the holes are slotted and you might gain a little there. Surgery to shorten the whole thing shouldn't be rocket science. Take it all apart and take the tube and shaft to a good machine shop or welder and tell them how much you want out.
Old 12-05-2012, 06:34 PM
72Truckin 72Truckin is offline
72Truckin is starting off with a positive reputation.
Im with you on the steering column being too long.
For now you can always get a smaller diameter steering wheel, which will give a lil extra space
I may either swap out the column or cut it down to a shorter length
Old 12-06-2012, 06:20 AM
Corkwheats Corkwheats is offline
Corkwheats is starting off with a positive reputation.
I'm with ya on the steering wheel being up in your face - I bought my 71 ranger XLT last month, and noticed that.
As fate would have it, my steering column (shifter) broke, and I'm installing a new column. I found one locally for $40 which is a steal. I'm guessing it will be the same as the old one - a bit too long.
What I really wanna do (down the road) is install a 78/79 Ford Truck/Bronco Tilt Steering Column. They will bolt in with only a few tweaks from what I've read. They have them regularly on EBay for $100 - $150. If I had the money, that's what I'd do.
Good luck, and Happy Holidays!
Bob
Old 12-06-2012, 07:47 AM
Shorter steering stem length with tilt woukd be
Old 12-06-2012, 09:59 AM
Bob
You'll be darn lucky to find one in that price range.
Old 12-06-2012, 12:15 PM
Willowbilly, you seem well versed in the art of modifications... how much effort. Will it take to make the conversion to the. 78/79 Bronco tilt steeri ng?
Old 12-06-2012, 12:19 PM
Quote:
Guys,
Check it out:
67 79 Ford Truck F100 Pickup and 78 9 Bronco Tilt Steering Column Good | eBay
73 74 75 76 77 78 79 Ford Pickup Keyless Tilt Automatic Shift Steering Column | eBay
78 79 Ford Truck Bronco Tilt Steering Column Rebuilt | eBay
There was one on there last week for $100. I'm passing this along to you guys, cause I can't swing it right now. Hopefully, it will do somebody some good.
Take Care!
Bob
Old 12-06-2012, 02:17 PM
Quote:
That's one mod I've never done but read up on it some. I don't think it's too hard, just the wiring to sort out. I could point you to some good info on "that other" site but a few guys here seem to get testy when we do that.
power steering conversion HillBillyBuddha 1961 - 1966 F-100 & Larger F-Series Trucks 10 07-05-2015 02:10 PM
1966 f100 steering TheRick505 1961 - 1966 F-100 & Larger F-Series Trucks 10 04-01-2014 11:46 AM
64 F100 steering column svolpone 1961 - 1966 F-100 & Larger F-Series Trucks 23 04-01-2014 08:53 AM
77 F250 4x4 M/T steering column help NMFirstF2504X4 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-31-2013 08:18 AM
Suggestions Needed: Steering Column Length for F-1 ralphhood3 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 07-13-2011 06:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
