2003 Expedition wont start
Ok this is my first post here and I hope you guys can help.
2003 Ford expedition XLT
I just replaced a crank sensor, plugs, #8 coil pack and all the boots on the other packs.
when I got done I started the truck and it ran like a dream!!!
after about 2 minutes of running I shut the truck off cleaned up and went in side to change.
the wife and I were going to take the truck for a ride jjust to make sure all was well about 15-2O min later we came out to take the truck for a ride and it will not crank.
from what have read i THINK the anti theft is activated but im not sure. My key FOB remote will not work replaced the battery to make sure.
I have also checked the boards ad tryed to "reset" my anti theft but that didnt do it . i have read about a valet button but i do not see one on my truck. any help is greatly apprecated.
Jerry
Jerry
Do you have any optional security system, whether aftermarket or from Ford, installed? In the factory configuration, there is no interaction between the starter circuit and the remote keyless system. However, many add-on security systems include some kind of starter disable feature.
In your first post you were talking about it not cranking with the key and then you said you also tried the FOB. I took that to mean your FOB had the remote start option. So sorry for the confusion.
The anti-theft (PATS) disables the ignition and fuel systems, it does not keep the starter from cranking. That being said, I would dismiss the PATS for now and focus on a loss of power common to both the starter and FOB circuits.
http://www.motorcraftservice.com/vdi...ts_job_aid.pdf
