Alternator bracket - Ford Truck Enthusiasts Forums
Alternator bracket
Old 12-05-2012, 03:27 PM
K9sicem's Avatar
K9sicem K9sicem is offline
K9sicem is starting off with a positive reputation.
Alternator bracket
I had time in the shop last night so I made this bracket to change over to an alternator. I have the generator but I'm not sure it's working. I know the alternators good and the backet only took me 1/2 hour to make.
You just got to love all the room the straight 6's have to work with.
Old 12-05-2012, 04:20 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
Alternator is a better charging device. And if the gen hasn't been used in a while you'd need to flash the field to bring it back to life. Many old airplanes still use generators because of the paperwork and cost involved with making the change. Many guys only fly their birds once a year. Guarantee they need their gen flashed.
Old 12-05-2012, 07:12 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Quote:
Are you referring to "Polarizing", a generator! That only involves disconnecting the field wire and the battery wire from the genny and touching them together momentarily without the engine running. Not really that big a deal.
Old 12-05-2012, 07:31 PM
vntgtrk's Avatar
Quote:
Same difference. Us A&P mechs use different terminology, so peeps won't notice us dragging our knuckles on the ground.
Old 12-06-2012, 11:15 AM
willowbilly3 willowbilly3 is offline
willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.
Don't need to "flash" an alternator. Is that a Cheby alternator? Ford's S3 is much superior and only requires one extra wire from the ignition switch "on" source. Plus the regulator and brushes are accessible from the outside if they ever need serviced.
Old 12-06-2012, 11:32 AM
vntgtrk's Avatar
Quote:
Correct. But I've seen peeps try and screw up a perfectly good alt. I've also seen gens discarded that were perfectly good. As far as alt choice, it's a matter of preference. I've also made the mistake of installing a 'one wire' GM alt without the needed diode block, etc. mods needed to have it work correctly. But my Ford 9N tractor charges well after the conversion. I 86'ed the gen because it sits all winter. I just want the dang thang to start and charge the batt when it's time to start mowing my 13 acres.
Alternator Bracket Bigtom04 Excursion - King of SUVs 3 02-08-2016 11:34 AM
Alternator upgrade swmr1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 06-27-2015 10:13 PM
alternator bracket mustang81 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 12-29-2014 09:31 AM
Alternator bracket svolpone Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 3 12-10-2014 09:20 PM
292 Alternator bracket for chevy alternator svolpone 1961 - 1966 F-100 & Larger F-Series Trucks 5 12-09-2014 04:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
