Radiator
My personal feeling is that you will not find one much cheaper than that.
If you buy a non-specific one, it may be less expensive, but could cost you extra by way of having to fabricate mounts, different hoses, etc.
As far as finding a used one, I would want to have any used one I purchased gone through, so add that to the price of the cheaper used part.
Four hundred bucks is really not muh money to spend for a part that, once finished, you can forget about for the next ten years or so, assuming you regularly service your cooling system.
I used a radiator from champion radiator. It's made for a 1956 f 100 truck. only difference a little bit narrower. Easy fix with minor brackets. truck never runs above thermostat opening of 180 degrees. 2 row aluminum radiator with choice of right or left lower outlet. I paid 175.00 I see they have them on sale now for $159.00!!! Google champion radiator
Risingphoenixtowing
08-10-2018 11:29 AM
triumph1200
1947 and Older Ford Trucks
03-08-2017 08:47 PM
52 USCG Panel
35
05-13-2016 05:29 PM
John & Old Ford
13
07-28-2012 11:04 AM
low springs
08-02-2007 06:58 PM
