Ford F-250 460 MPG smog - Ford Truck Enthusiasts Forums
Old 12-05-2012, 01:43 PM
fords4life0319 fords4life0319 is offline
fords4life0319 is starting off with a positive reputation.
I have a F-250 with a 460 CID and a 5 speed in it, I'm looking into bypassing all the emissions crap and wanted to see if anyone could tell me what what all would be involved and what kind of MPG I might pick up in doing so. I'm also open to any other tips for picking up any extra MPG! Thanks!
Old 12-05-2012, 01:53 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Removing what little smog equipment there is won't have any positive effect on fuel milage and may even hurt it a bit if you disable EGR. What axle gear ratio does the truck have? If it's not used for heavy towing then a swap to 3.55 gears(assuming you now have 4.10s) would be the best thing you could do.
Old 12-05-2012, 03:37 PM
DIYiT's Avatar
DIYiT DIYiT is offline
DIYiT has a good reputation on FTE.DIYiT has a good reputation on FTE.
You'll see no increase in MPGs. I've removed the A.I.R. pump, the catalytic converter, and all of the associated lines, and I saw no difference except one less tube to reach around while working on the engine.
Unless your EGR isn't functioning for some reason, leave it alone. It actually helps you achieve higher fuel mileage.
1996 F250 SC 4x4 460 mpg - first measurement and other ramblings lcgeek 1987 - 1996 F150 & Larger F-Series Trucks 24 10-01-2014 09:32 PM
460 Cid mpg fords4life0319 1987 - 1996 F150 & Larger F-Series Trucks 17 12-08-2012 01:57 PM
MPG in your Ford 460. glovemeister 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 37 10-28-2012 03:18 PM
7.5 460 Mpg ? 93liftedxlt 1987 - 1996 F150 & Larger F-Series Trucks 9 02-24-2007 05:29 PM
93 F350 racoonbandit 1987 - 1996 F150 & Larger F-Series Trucks 1 04-20-2006 01:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
