55 F250 Spring Lock Pin - Ford Truck Enthusiasts Forums
Old 12-04-2012, 10:17 PM
Harrier's Avatar
Harrier Harrier is offline
Harrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud ofHarrier has much to be proud of
Hey guys.
When I was putting my rear springs back on, I managed to strip one of the spring lock pins. I ordered some from Mid-Fifty, but I have a couple that are longer than the ones you get from there.
Do you know where I might be able to find the longer ones? The regular ones seem too short for a couple of spots. The two on the right are ones out of the truck, the one on the left is the Mid-Fifty one.
I guess I could see if I can repair the threads....
Old 12-04-2012, 10:40 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
It looks to me like the nut stripped, not the pin.
These pins are used for several things, see pic below. I suspect the shorter ones are the same as the kingpin locks, too.
Might try JobLot for these
Old 12-05-2012, 06:56 AM
Harrier's Avatar
Ross, thanks for the info. I have that book myself...my brain must have slipped a gear not to think of looking there. I will get in touch with JobLot.
I went out and measured my two pins, yep that is their length and the numbers listed in the book are correct.....I need to study that book more.
Old 12-05-2012, 02:39 PM
Harrier's Avatar
I emailed both JobLot and Mid-Fifty.
Mid Fifty already replied, they have it; Part #F2-2830
The shorter one is just part#2830
They are currently $2.50 for either part if anyone is interested.
Polyurethane bushings for the rear springs? Schuyles 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 07-25-2014 01:51 PM
Axle and part Identification Harrier 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 08-29-2011 07:23 AM
Kudos to Mid-Fifties Store lorolr 1948 - 1956 F1, F100 & Larger F-Series Trucks 37 04-01-2011 03:38 PM
Rear leaf install question undertow91 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 07-06-2008 09:12 PM
how Mid-Fiftys axle flip kit stacks up for 57-60 owners 60RatRod 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 07-24-2007 08:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
