Factory 4X4?
Old 01-18-2012, 11:53 AM
rocdril's Avatar
rocdril
rocdril is offline
Factory 4X4?
I tried a search and did not come up with much. I am trying to find out if all factory 4X4 vin #s start with F26 for a 250? More specifically a 1960. Where these all factory 4x4s? or were they still sent to Marmon Herrington?
I am looking at a 1960 4x4 and am being told it is factory but the vin # starts with F25.
Thanks in advance for any replies!
Old 01-18-2012, 12:40 PM
1959_f100's Avatar
1959_f100
1959_f100 is offline
it should be f26 for factory 4x4. if it was done some were else it will probably be f25
Old 01-18-2012, 01:18 PM
59flatbedford's Avatar
59flatbedford
59flatbedford is offline
well im not 100 percent on this but i think the f11 anf f26 vin numbers were for the later trucks. the vin on the 57-60 trucks start with f10 or f25 and the only way to tell a factory is by the front axle code.
Old 01-18-2012, 02:19 PM
rocdril's Avatar
rocdril
rocdril is offline
Thank you for both replies, I am still just as confused.
Old 01-18-2012, 02:27 PM
Romak's Avatar
Romak
Romak is offline
if numberdummy doesnt chime in here shortly, shoot him a message and he should be able to straighten it out for you.
Old 01-18-2012, 03:06 PM
1959_f100's Avatar
1959_f100
LMC vin decoder says f11 and f26 are for 4x4. not sure how acurate it is. but im guessing if there gonna put it in there magazine it should have some truth
Old 01-18-2012, 03:55 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
1959 f100 Here is a picture of my data tag from the glovebox! Serial number shows F25---- then below that After color and before date code it shows F28C i'm not sure wate the C after F28 means, and of course the front axle code is there on the end of the middle line.
Clear as mud right?
Wally
[IMG][/IMG]
Old 01-18-2012, 04:14 PM
59flatbedford
Yea if I remember right the lmc catalogue is wrong on the vin but I'm not sure.
Old 01-18-2012, 08:33 PM
spurredon's Avatar
spurredon
spurredon is offline
Clear as mud right?
Wally
[IMG][/IMG]
Under the axel code section of this tag it reads "04 B". The "04", is the rear axel ratio which would be 4.56-5M ratio, according to the '60 shop manual and the "B", is for the front axel 4.55 ratio (4-wheel drive). So yes, the plate indicates 4- wheel drive! That's my story and I'm sticking to it!
Old 01-19-2012, 05:00 AM
rocdril's Avatar
rocdril
rocdril is offline
Thanks again for the replies!
Old 01-19-2012, 05:10 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
[IMG][/IMG]
This is a 1959 F250 with factory installed 4WD. According to the 1957/63 Ford Truck Parts Catalog, both F10/F11 .. F25/F26 Series codes were used in 1959/60.
The MODEL code defined whether the truck was 2WD or 4WD / 1959 had the code, but the term MODEL itself wasn't listed on Rating/Warranty Plates until 1960.
F25 = F250.
C = 292 2V
9 = 1959.
R = San Jose CA Assembly Plant.
38460 = 1959 Numerical Sequence of Assembly, the trucks specific serial number.
118" Wheelbase.
C = Wedgewood Blue.
Model: F28C = F250 4WD Cab & Chassis / 7,400 lbs. GVWR
01F: Assembled June 1, 1959.
A = Ford 3 Speed Manual Transmission.
04B: 04 = Dana 60 Rear Axle / 4.56-1 / non Limited Slip / 5,000 lb. Rear Axle Capacity // B = Dana 44 Front Driving Axle / 4.55-1 / 3,000 lb. Front Axle Capacity.
7,400 lbs. Gross Vehicle Weight Rating.
158 net HP @ 4,000 RPM
8130 = Domestic Special Order Number. The truck was special ordered by the original purchaser, not "bought off the lot."
Domestic Special Order means that special equipment was installed that was not an RPO (Regular Productrion Order). After the truck left the assembly line, FoMoCo sent the truck out to have the equipment installed.
The DSO number was important because if parts were required for the special equipment, the dealer would contact FoMoCo, pass along this number.
FoMoCo would look up the order, then tell the dealer where to get the parts. This same system is used today.
Old 01-19-2012, 05:49 AM
rocdril's Avatar
rocdril
rocdril is offline
Thank you Bill.
Old 01-19-2012, 06:01 AM
NumberDummy
LMC's (and FTE's) VIN decoders aren't worth TWO CENTS, have multiple errors and omissions.
Old 01-19-2012, 06:12 AM
1959_f100's Avatar
1959_f100
But your syaing that f26 and f11 does mean 4x4
Old 01-19-2012, 06:30 AM
NumberDummy
Parts catalog lists these series codes for 1959/60, but does not specifically state they refer to 4WD's.
1959/60: It's the MODEL code that defines whether the truck is 2WD or 4WD.
And, FoMoCo did not always list front driving axle codes within the AXLE code for 4WD's...especially after 1966.
Quick Reply: Factory 4X4?
