cant seem to get rear shock mount off
Old 12-04-2012, 08:46 PM
fdude64's Avatar
fdude64
fdude64 is offline
ok so I broke a shock mount the other day and im trying to replace it. ground the rivits off the outside of the frame and cant get them out to get shock mount off. I have tried air hammer,small sledge and a punch no luck, just beat my brains out. anyone got any tricks ?
Old 12-04-2012, 09:20 PM
Freightrain's Avatar
Freightrain
Freightrain is offline
Usually once the head of rivet is off, a punch(air chisel) to the center should drive it out.
Make sure you have the whole head off? You can usually see the outline of the hole when you do. Never had much trouble, even with hammer and punch to get them out.
Old 12-04-2012, 09:32 PM
fdude64's Avatar
fdude64
fdude64 is offline
maybe I haven't got the whole thing off but im pretty sure I did. I could see the outline of the hole and ground totally smooth with frame
Old 12-04-2012, 09:46 PM
Freightrain
Well, it sounds like you got it all. They get crimped pretty tight in the hole, so maybe a touch of heat?? then air chisel.
Old 12-04-2012, 09:48 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
You can either heat the center of the rivet w a torch to soften it then punch out or drill w a 3/8 bit into the center of the rivet then hit w punch(that will give the riet some room to collapse on its self
Old 12-04-2012, 10:06 PM
fdude64's Avatar
fdude64
fdude64 is offline
thanks brad I will try that tomorrow. you would think all the rivets I took out doing my swap I would have figured out an easier way
alaskawoobie
1997 - 2003 F150
05-07-2013 03:35 PM
DaveBB
1997-2006 Expedition & Navigator
18
09-24-2012 06:31 PM
jamie7375
1999 to 2016 Super Duty
12-10-2008 02:38 PM
sigtauenus
18
11-08-2007 01:58 PM
'88_F-150
03-24-2005 04:36 PM
Quick Reply: cant seem to get rear shock mount off
