Full floating axles - Ford Truck Enthusiasts Forums
Full floating axles
Old 05-23-2003, 08:00 PM
mpalamaras mpalamaras is offline
mpalamaras is starting off with a positive reputation.
Full floating axles
What is a full floating axle and what are the advantages?
Is full float the same as free floating, where you can lock in the axle or let it float?
Old 05-23-2003, 08:32 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Full floating axles
A Full floating axle is one that does not support any weight from the truck by the axle shafts. Extra bearings and such keep the weight off the axle shaft. These are much stronger than their opposite, semi-float. Semi floaters have a portion of the vehicles weight on the axle shafts as well as the axle tubes/housing.
Old 05-24-2003, 07:49 AM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
Full floating axles
Higher load limit, usually much stronger, and you will not lose your whole wheel if an axle shaft or C-clip breaks. If you are lucky, you can even drive it out with 3 wheel drive if you have a locker.
Old 05-24-2003, 10:48 AM
rogue69 rogue69 is offline
rogue69 is starting off with a positive reputation.
Full floating axles
What is a 79 9 inch axel and a 78 dana 60 ? Full or semi?
Old 05-24-2003, 11:45 PM
deere81 deere81 is offline
deere81 is starting off with a positive reputation.
Full floating axles
The 9 in. rearend is a semi floating and the dana 60 is a full floating rearend.
Old 05-26-2003, 06:50 PM
bearfoot_25 bearfoot_25 is offline
bearfoot_25 is starting off with a positive reputation.
Full floating axles
not all dana 60s are full floating, esp on fords!!!
Old 05-27-2003, 05:38 PM
idunno idunno is offline
idunno is starting off with a positive reputation.
Full floating axles
What type axle is the Dana 80?
Thanks
Rear Differential/Axle Identification LvBohemian 1987 - 1996 F150 & Larger F-Series Trucks 1 10-29-2014 10:51 AM
Full float vs. semi float 10.25 blucollar4xford Offroad & 4x4 17 07-12-2011 04:04 AM
85 ford rear brakes full float axle fordflatbed 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 03-27-2011 09:22 AM
BEST YEAR FORD DANA 60 REAR AXLE robjs111 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-26-2011 10:37 PM
rear axle nut torque spec RoughIdle Clutch, Transmission, Differential, Axle & Transfer Case 2 12-19-2009 08:01 PM
Tags
1968, 2002, 9, axcels, axle, axles, f150, f250, f350, floater, floatimg, floating, ford, free, full, inch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
