HELP "borg warner 1345"
ok about three mouths ago my np205 case cracked and went south, so i have a 1985 f250 light duty with 351w and c6 so i went and priced a used np205 and it was like $425 at a local junk yard so i did go with that, so i bought my buddys 1980 f350 ttb single cab with a blowen 351m, c6 and 13-45 borg for $150 so i swaped the t-cases and been driving it and it ten times better but i dont know if it has netural or 4 low if you have any idea plz reply thank u
The Borg Warner 1345 has a low and a nuetral postion. With the shift lever pushed all the way forward (toward dash) the transfer case is in 2WD, pull back one postion it is in 4WD-Hi, pull back again it is in Neutral, one more pull puts it in 4WD-Lo.
Note to go into 4WD-LO, the vehcile should be stopped, hubs locked in, and transmission put in neutral.
FWIW, the NP205 was dropped after 1979. If you managed to crack one of those, you must have dropped your truck on a rock that was magically shaped to hit only your transfer case. The NP205 featured a one-piece cast iron case, so it's one of the strongest (and heaviest) transfer cases ever made.
You probably had an NP208. The NP208 is light weight aluminum, and very susceptible to cracking.
As for the BW1345, those were pretty rare in our trucks, especially in a 1980. BorgWarner didn't see much use until the mid 80's.
BTW, I want that blown 351M. I need parts.
also note that with the hubs locked, you can shift between 2hi and 4hi at any speed, as long as you aren't slipping your tires at the time. don't try it with the hubs unlocked unless stopped.
also note that you may put the t-case in 4-lo with the hubs unlocked, if you want the lower gears in 2wd for backing a trailer into a tight space or whatever.
74FordCrewCab1stimer
03-03-2014 07:54 AM
conyers73
12-12-2013 07:31 PM
daphill
06-06-2010 01:17 AM
shooterg22
03-27-2006 07:12 PM
sl9mk
04-09-2004 10:15 AM
