SCAN GAUGE II - Ford Truck Enthusiasts Forums
SCAN GAUGE II
Old 12-03-2012, 10:36 PM
04badford 04badford is offline
04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future
SCAN GAUGE II
Hello Comrades,I was playing with my scan gauge and got worried can you guy interpet my reading Please Thank you.
KOEO
VLT=12.3 lo=13.5 hi=13.9
FVP=12.0 lo=13.0 hi=13.5/14.0
FLP=12.5 lo=13.0/13.5 hi=13.5 for the most /14.0
batt=12 start 10./11. lo=13 hi =13 for the most/14. /14.1
FMP= 48.0
I did notice a lot of vlt,fvp,flp jump around at 1950 and 1500 rpms this is what they where at 1950 rpm
vlt =13.6/13.8/14.1
fvp=13.5/14.0/13.8
flp=13.5/14.0/13.8
batt=13/14/13
fmp=43/45.5 fmp at 1500 rpm 48.5
I never had my gauge set to these because we were fixing other issuses thanks again guys .
Old 12-03-2012, 10:44 PM
the almighty schmuck the almighty schmuck is offline
the almighty schmuck is starting off with a positive reputation.
looks like batteries and ficm are going out
Old 12-03-2012, 11:03 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Ford FICM Cutoff is 40 volts IIRC (Maybe 42volts cutoff)
the batterys didnt Look to Bad but Hard to tell looking at Voltage
If you have the Old Fashion Water Batterys the Best way I have found to test them at Home is a Battery Hydrometer and Test Each Cell
My Batterys Looked Good Voltage wise But Hydro test Failed
A Fulley charged Battery should Read 12.68volts Keep in mind .10-.20volts less at OBDII Port
Clean cables and Grounds see if that helps the FICM Volts any worth a shot IDK
But Next time you take Sensor Values do this
KOEO
Low Idel (Truck Idel on its Own)
High Idel (2500 Rpm)
I have Ford Operating Values for these 3 Above
All in Park or Nuetral
Also check FICM Voltage Under LOAD say 55mph++ WOT up a Hill Take FICM Voltage Again
Old 12-03-2012, 11:10 PM
Fal-308-Win's Avatar
Fal-308-Win Fal-308-Win is offline
Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.Fal-308-Win has a great reputation on FTE.
Check it going up the Vallejo Grade. I bet you see 32 V at the top
Old 12-03-2012, 11:23 PM
yes your are right , those first ones are the second are at operating between 1,950rpm , I had set the gauge to those and seen the changes when driving , I hit the alta mont pass this morning and back no load fmp43/45.5 down in the flats same rpm 48/48.5 that plus the other readings got me thinking NO WORRIED.
Old 12-03-2012, 11:30 PM
Just keep your foot out of it, no hurry but you need to call Ed.
Old 12-04-2012, 12:14 AM
Thanks fal 308, do you think the alt volts look ok seems like Ive been reading alot about the alts going out its the same alt sence 04 ,but batts are 1 yr old,if I do replace seems that benny likes the DC thats what will go back in
Old 12-04-2012, 02:01 AM
Alt looks OK, mines 6 yrs. Old. Bench test is free.
Old 12-04-2012, 08:24 AM
kidoo kidoo is offline
kidoo is starting off with a positive reputation.
I did not know that the FICM could drop going uphill.
Old 12-04-2012, 09:08 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Anything under 45V indicates a toasted FICM.
Old 12-04-2012, 08:02 PM
Quote:
A better way to put it would be to say " under a load ", and the easiest way to work the truck is to drive up a steep grade. Mine was showing 48 to 46 V in the drive way and after learning how to use a scangage 2 I noticed every time I climbed a grade it would drop to the 30's. One time it sank to the high twenty's. It got so I wouldn't watch the speedometer but watch the scangage and Back off it to keep the volts high. By the time I got to the top I was doing 45,50 MPH. Ed fixed it and now shows 48.5, 49 v all day long. Best mod so far.
Old 12-05-2012, 01:06 AM
Thanks fal and Benny ,for the Input Mucho, I will Do all that was noted from yall, thanks for the advise. I will let you guys know what I find.
Old 12-06-2012, 11:23 PM
Ok, I took my truck to the local Ac delco shop just to check myself and the scangauge mostly,what we found was that the ALT is going out,charging at 11.6 and lo Idiol was 12.1 even thou it went up to 14./14.1 at the most too low . the unit is 110 amp from stock , now back to the ficm It never made it to 48.0 , 38/35.some cases 33 mostly 46.5, SOOOO, what goes first? Batteries are up to full charge according to the techs machine and the scan gauge .
Old 12-07-2012, 09:19 PM
Alt then Batts' then FICM
Old 12-07-2012, 10:54 PM
Fal-308, your not going to belive me, but does the scan >=,./? with me bat helt 14 alt 13.5/13.8 ficm 48/46= 33/35/48 all around the map, holy crap and really? Our weather is not much diff from yers over the other side of the hills now. tomarrow will be as benny noted clean batt posts, Ed will be called for the ficm per your as noted . and both will be replaced. now 110/115 amp alt that ford put in I dont have big stereo, campers, just horse trailer and some dump/car trailers.is the DC190 amp really nessary, and put the $ into the FICM? not forgetting the Batteries?Thanks for your help guys.
Truck runs rough, numbers show anything? 56fordfella 6.0L Power Stroke Diesel 101 12-13-2014 12:49 AM
P0267 and low FMP means I need Ed, right? davbeisner 6.0L Power Stroke Diesel 16 06-07-2014 04:07 PM
help me crunch my numbers superstroked6.0 6.0L Power Stroke Diesel 14 04-24-2014 06:49 PM
30.5 Volts for FICM (bad) but no reading for FLP andysam 6.0L Power Stroke Diesel 40 03-26-2014 06:18 PM
early 03 6.0 problems 190,000 miles USMCveteran 6.0L Power Stroke Diesel 123 01-27-2014 10:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
