05 E-350 Gasoline Wil Not Start
I have an 05 E350 Super Duty that recently developed a misfire/communication issue on coil pack f. I tested it with an obd scanner plugging it in or not and received the same code. It was due for a set of new plugs, so I replaced them as well as the coil pack. Started and ran the engine in the driveway for a half an hour and received no miss and no coil code. I assumed it was fixed.. Drove it down the road to test it and about a half mile the engine just quit and all gauges dropped. Only tried cranking the engine a few times and the battery died quickly. The engine will not restart. The obd will not communicate with the ECM. Any one might have a clue your response is very much appreciated.
Thanks
Jerry
Thanks
Jerry
Also noticed a slight exhaust manifold leak sound that wasn't present before. The symptoms are similar to the 05/06 escape issues with wrong plug install at factory causing the coil packs to go and pcm/ecu to fail. I used autolite plugs instead of motorcraft and a coil from autozone not ford oem. I didn't see an issue using different plugs and coils.
Jerry
Jerry
I checked the wire harness and found an area that was melted on the exhaust return on the drivers side. The factory placed heat resistant rapping around the pipe and a metal tape shield around the wire harness. The harness was in the correct location from the factory. It is just a bad spot to place the wiring. It would have caught fire and came close to doing so. As soon as I find a way to post pictures I will so others can see the issue and prevent it.
I have checked all the fuses and they are good. I have a few that reed low or negative voltage(smaller fuses) like the horn relay switch. I replaced the ecm (No Change) and patched the wiring to the best of my ability's. I found a 30 amp fuse blown in the cabin and replaced it and now the check gauges prompt went out. There are a few low voltage (meaning not 12 v) .5 volts on the fuse box in the cabin. The distribution box receives 12v so i assume the fuses do get power. I also replaced the battery because this ordeal fried it. Any ideas where to go from here would be appreciated.
GuitarJesus
08-24-2017 12:00 AM
