heater blows cool air - Ford Truck Enthusiasts Forums
Old 12-02-2012, 04:40 PM
stihlcut stihlcut is offline
stihlcut is starting off with a positive reputation.
O.k. so I took the dive into a new heater core, as the heater was not getting hot. These are the things I did while on my adventure.
1. Before reinstalling the hoses, I blew thru them to make sure of no clogs...water flew out the other hose..no problem..no clog.
2. inspected mix door not cracked or broken...no problem
3.actuator opens and closes ok, I assume, I can hear the motor run and the door thump closed...no problem
4. water and anti freeze level good....no problem
Start vehicle,let warm up, turn on heat.....No Heat...hmmm
5. check hoses at core, one is hot ,the other is not....Problem...
any suggestions?
97 f150 4x4
Old 12-02-2012, 06:06 PM
BCHauler's Avatar
BCHauler BCHauler is offline
BCHauler has a good reputation on FTE.BCHauler has a good reputation on FTE.
I'll bet your heater control **** isn't actually turning the control shaft. Grab the temperature **** and pull it off. Check the inside of the **** - is the indexed part broken? Check the white plastic shaft the **** mounts on, is it stripped? on my truck, the problem was a stripped shaft. Using needle nose pliers, I was able to turn the shaft and -low and behold- heat. The next step was then to replace the heater panel assembly.
Keep us posted.
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Weak water pump. Pull it and see how much of the impeller is left.
Old 12-02-2012, 06:24 PM
Quote:
I have thought of that, but have not checked it yet. To the best of my knowledge, over 200,00 mi. and I have never replaced it
Old 12-02-2012, 06:26 PM
Quote:
Keep us posted.
everything else seems to work ok theoretically, but that is something to try that I have never thought of
Old 12-02-2012, 11:38 PM
BCHauler's Avatar
It only takes 30 seconds too. Just yank the **** off and have a peak. Here's hoping that is what it is. Simple and easy to fix.
Old 12-03-2012, 05:08 AM
A stripped **** won't cause the heater hoses to have different temps. Guess again.
Old 12-03-2012, 05:58 AM
I did not pull the water pump because it does not run hot the temps are good. With that said, it acts like maybe not enough circulation pressure to push thru the core being the hoses circulate from the back of the engine. hmmm....
Old 12-03-2012, 12:28 PM
Yeah. That's often caused by a worn out water pump.
Old 12-03-2012, 01:50 PM
Then next step is finish the dash and pull the pump...will advise of findings
Old 12-05-2012, 05:16 PM
UPDATE:
impeller on water pump non existent...no water circulation and never ran hot...WOW...replaced water pump and now there is heat
Old 12-05-2012, 07:51 PM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
Good call SHO, I've heard of other vehicles prone to w/pump impeller wear but not these engines. Maybe just a mileage factor?
Old 12-05-2012, 08:53 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is online now
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
i have not heard of impeller failure either. Is this due to bad antifreeze or is there some other cause ?
Old 12-05-2012, 09:14 PM
Can you take a photo of the old one?
Old 12-06-2012, 12:32 AM
Torky2 Torky2 is offline
Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.
The Model T didn't have a water pump either. Woo Hoo! Now a Thermosiphon F-150!
Sure seems those heads would glow in no time, and trigger the alternating firing fail-safe scheme into shutdown.
2001 f150 5.4 lariate super crew poor heat bigtim12019 1997 - 2003 F150 15 03-26-2017 12:17 AM
heater issues 2000 expedition jcstu 1997-2006 Expedition & Navigator 18 02-09-2015 11:25 PM
1999 Expy 4.6 Heat FIXED! - You won't believe how! developer 1997-2006 Expedition & Navigator 8 02-03-2015 08:33 AM
No heater...wtf 73 ford guy 1987 - 1996 F150 & Larger F-Series Trucks 78 10-14-2013 12:17 AM
Heater problem leinieman 1997-2006 Expedition & Navigator 12 11-26-2012 08:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
