Engine is using oil why - Ford Truck Enthusiasts Forums
Old 12-02-2012, 04:38 PM
whalebus2112 whalebus2112 is offline
whalebus2112 is starting off with a positive reputation.
My truck is using about 2 quarts on a 700 mile round trip pulling 5ooo lbs threw the mountains. I just put a turbo on it but it used oil before the turbo . My engine has zero leaks and 98,000 original miles.
I have read about the cdr valve making this happen so how can I check this? I have a feeling that the valve seals are a little rotted because if I idle a while then take of it seems to smoke a little for a minute. Im sure that came from it sitting. What do you think?
Old 12-02-2012, 05:09 PM
kla94's Avatar
kla94 kla94 is offline
kla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputationkla94 has a superb reputation
Do a quick search at the top of the page. Cdr valve cleaning. Thats how I found it.
Old 12-02-2012, 05:12 PM
kla94's Avatar
By the way, take your breather inlet off at the turbo. If it's oily around the turbo inlet, thats a sign that the cdr valve needs cleaning or replaced.
Old 12-02-2012, 05:57 PM
can it cause that kind of oil consumption, a bad CDR
Old 12-02-2012, 09:25 PM
kla94's Avatar
Not sure if that's your only problem, but I have heard they cause pretty good oil consumption.
6 cylinder IDI... uh oh... yewdall Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 09-04-2013 11:14 PM
Valves starmilt Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 01-26-2010 09:56 PM
Oil leak on turbo 95 PSD willbd 1994.5 - 1997 7.3L Power Stroke Diesel 0 07-24-2009 09:00 PM
200,000 miles, Valves too tight? c_rossman Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 09-24-2003 08:55 AM
High Oil Consumption ? 73Power 1999 - 2003 7.3L Power Stroke Diesel 4 07-11-2002 09:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
