2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 expedition antenna wire routing
Old 12-06-2012, 02:24 PM
Cowman79's Avatar
Cowman79
Cowman79 is offline
Does anyone know the routing of the factory antenna wiring. I just installed an aftermarket stereo in my 07 expedition and am trying to find the wire routing for the antenna. I have always had poor reception even before changing out my stereo. I unhooked the window antenna with the stereo on and could tell no difference in reception. I noticed that the cable behind the stereo is a coax and the cable at the antenna is a pair of wires not coax. I was wondering if maybe someone knew where the connector was that change the cable from coax to cable. Any help would be greatly appreciated.
Old 12-06-2012, 06:29 PM
berry1234's Avatar
berry1234
berry1234 is offline
I belive it runs down the passenger door sils. Pull off the sills and see if you can spot the wires.
Old 12-06-2012, 07:28 PM
Cowman79's Avatar
Cowman79
Cowman79 is offline
from what I could tell behind the radio it went toward the driverside or atleast that is the direction of the wire loom I can only see it near the steering wheel after that it disapears. I will check the passenger side pillar.
Old 12-07-2012, 05:42 AM
eddiemoney's Avatar
eddiemoney
eddiemoney is offline
Its in the sills, make sure you are powering the amp for the antenna as well
Old 12-07-2012, 10:27 AM
Cowman79's Avatar
Cowman79
Cowman79 is offline
You are correct about the amp it was located on the passenger side back seat pillar. The problem wa I wasn't powering it up. I had not hooked up the power antenna connection on the stereo because I didn't think it needed to be hooked up. I guess I was wrong, the stations come in Loud and clear now. I have to say that I really like the sound of hd radio.
Thanks for all of the help.
Old 12-07-2012, 11:42 AM
berry1234's Avatar
berry1234
I am confused. There is a power antenna hook up in the factory wiring?
Did you use a wiring harness kit for the aftermarket stereo?
Old 12-07-2012, 01:06 PM
Cowman79's Avatar
Cowman79
Cowman79 is offline
I replaced my aftermarket radio with another aftermarket radio due to touchscreen issues. Also I was having problems with my rear dvd player. It was in a limited use mode because I didn't have the factory canbus stereo. To get the functionality back I installed a PAC module C2R-FRD1. This was a nice kit that connected between the factory harness and the aftermarket harness. The previous owner had an aftermarket unit put in but only used a wiring harness not a canbus module. They went down the same road I did because they cut a yellow/blue wire from the factory harness and connected it to a 12 volt switched power to give the amplifier power. When I seen they had cut the wire I reconnected it to the factory harness because I was using a different harness. When connecting my new pac harness to my stereo I didnt hook up the wiring for the power antenna because I didn't have a power antenna I didn't realize that the power antenna output actually turned on the antenna amplifier. In the end If I would have left there wiring alone I would have never had a problem. I was just trying to make the harness factory again. Guess I should have left well enough alone.
Old 12-07-2012, 01:22 PM
berry1234's Avatar
berry1234
Ahh! Got it. I was considering swapping out my factory HU for a aftermarket HU. Crutchfield kept pushing the PAC module, but I am still not sure exactly what it does. Can you explain that?
I don't use the rear seat entertainment controls at all, but want to keep the OEM amp/sub working.
Old 12-07-2012, 01:30 PM
Cowman79's Avatar
Cowman79
Cowman79 is offline
The pac module simulates the canbus so the rear dvd player will work properly. Also I think it actually sends to 12 volt switched power to the new stereo. If I recall there is no 12 volt switched power to the factory harness I think the factory stereo is turned on with the canbus. So you would either have to run a new switched hot or use the pac module. I think that your output for the amp from the aftermarket stereo would go through the pac module. I am not 100% sure if the output actually goes through the pac module or just through the wiring harness. I will say that the pac module was very easy to use. I was able to connect the new stereo harness and the pac module together while setting at the table and just go plug it all in the truck. highly recommended. I think there maybe a few other modules on the market that will do the same thing for you.
Old 12-07-2012, 01:59 PM
berry1234's Avatar
berry1234
Perfect, thanks for the info!
Old 12-07-2012, 02:05 PM
Cowman79's Avatar
Cowman79
Cowman79 is offline
any time. All I Can hope is that someone reads this and doesn't make the same mistakes as i did.
Race Chapman
12-11-2017 03:31 PM
87diesel
1997 - 2003 F150
12-12-2015 11:45 PM
67nukeford
1997 - 2003 F150
08-30-2015 10:05 AM
kspilkinton
1997 - 2003 F150
01-05-2004 12:44 AM
Quick Reply: 2007 expedition antenna wire routing
