heat only works on lower settings
if the blower is running, and you dont have hot air, then the heater core is plugged, the water is not hot, or the damper is broken in the duct that mixes the hot and cool air to get that rigth temp.
--- is the temp gauge about 1/2 way up ? that tells you the thermostat is working.
---are the hoses to and from the heater hot ? (under the hood). heater outlet should be not as hot if your getting heat transfer to inside air.
---is the air mixing motor and damper door moving ? This is behind the dash below the radio. Might be able to take off the plastic and see more. I think you can lay on drivers floor and look up under the radiator and see the motor. Have someone stroke the **** from hot to cold and look to see that things are moving.
Nico80
11-24-2018 05:08 AM
