Manual transmission Swap
Ok, here's a link to the thread I was thinking about....diff forum, though:
Auto to Manual Converstion - PowerStrokeNation : Ford Powerstroke Diesel Forum
Good luck if you go for it...I love the idea, myself!
You'll need the following:
6 Speed floor board hump out of junk yard truck.
Clutch Pedal Assembly
ZF6 Transmission and Transfercase
A pre-bleed Master/Slave Cylinder kit from Ford
New clutch and flywheel
Manual PCM (Optional)
The output shaft of the manual and the auto tranny's are different. If you don't have the manual transfer case don't worry. You can switch the input shaft of the transfer case to make it work with the manual.
devall97obs7.3
16
10-15-2014 09:41 PM
