New Guy with some Fords
My apologies. I was suffering from rectal/cranial inversion when I first read your initial posting. In my deluded state i thought that you had a 54 truck and a 59 truck. After seeing your pic and rereading what you posted I realise you have a 54 truck with a 59 bed (not to mentioned the lengthened frame.
My bed advice still holds though, there are lots of good beds out there currently being used as trailers. If you're not in a rush and keep your eyes and ears open donor frames come up on a regular basis. Keep an eye on Craigslist and make friends around here and something is bound to come up.
Good luck, it looks like a decent start to a nice project
Bobby
Bobby
I would definitely suggest a replacement frame. WARNING: Most state use the serial # stamped on the frame as the legal ID for the entire vehicle. If you replace the frame with a new one make sure you get a transferable registration or title that matches the # stamped on the frame. The # is usually found on top the pass side rail someplace between the front crossmember and firewall. It is not stamped deeply and often obscured by a coat of rust or paint.
Hello and welcome to the forum.
I always say to make sure that you have a title in hand...with your name on it before you start dumping money into the project.
Some states can be pretty picky (Kentucky seems to be one of those). Others seem to have things down. I call it the virgin DMV scenario. When somebody walks in with a complicated title question, it's like it is the first time they've ever seen the problem. Could it be that maybe some of us here were the first guys to show up at our respective local DMV's with an old truck that "doesn't show up in the system".
By the way, California seems to know what to do. I can't say how Nevada will be.
On the frame thing...keep your eyes open...you'll find one pretty soon.
Dan
Dan
Big Bad VooDoo Daddy
07-24-2003 12:04 AM
