need help on leveling kit
I cut your post from the thread you originally posted it in and started a new thread for it here.
Next time when you have a problem, start your own thread. It's better than asking a question in a thread dedicated to posting pictures of user's trucks.
Welcome to FTE!
Stewart
Welcome to FTE!
Stewart
I have a 2.5 inch Autospring level kit and just put 295/60/20 Nitto Trail Grapplers on my truck last week. I have the factory 20's as well. I have a rub at full lock to the right on my upper control arm on the left side and when turning right the right front rubs on the frame just ahead of the control arm mounts. No big deal and it is better now since I inflated the tires from 35 psi that the shop put in them to 43 psi. They are 10 ply tires rated for 80 psi so they are fine at 43 psi. I had Nitto's before with 275/65/20 Terra Grapplers and they did not rub at all. The Terra's were 34x11x20 and the Trail's are 35x12x20 and look really good and not stuffed in the wheel wells. I have no rubbing on the fender flares or front valence at all.
Good luck.....
Good luck.....
F250_
03-24-2009 03:25 PM
