Dancing speedometer pointer - Ford Truck Enthusiasts Forums
Old 11-30-2012, 03:13 PM
bobcf's Avatar
bobcf bobcf is offline
bobcf is starting off with a positive reputation.
I have a 95 f15 351w e4od. This morning the ABS light came on, the speedometer is dancing wildly and the transmission is not shifting right. Where do I start? Does the speedometer get its count from the sensore on top of the rear diferental?
Thanks
Bob
Old 11-30-2012, 04:20 PM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
Yes it does, and that's a good place to start.
Old 11-30-2012, 04:28 PM
Blown349 Blown349 is offline
Blown349 is starting off with a positive reputation.
What kind of music does it like?
I second the VSS sensor on top of the rear axle or the wiring to it.
You can check 'Codes' to see what's up.
Old 12-01-2012, 09:08 AM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
X3...check for codes. Very rarely does the VSS go bad. We have seen many folks on this forum replace the VSS only to find they have the same issue. It is advisable to remove the VSS to inspect it and clean it off then re-install. Drive the vehicle to see if the issue is resolved.
If you still have the problem it's time to breakout the meter to measure the VSS signal at the input to the PSOM behind the dash. Subford has also mentioned there is a RABS test harness located on the driver side firewall. The VSS signal goes to the RABS control module, located behind the glovebox, on it's way to the PSOM. You can place your meter there too. The test is to jack up the rear axle, after blocking the front wheels, running the truck up to an indicated ~30MPH while watching the meter. The voltage should smoothly rise to approximately 3.5 Volts. If the voltage is low, try disconnecting the RABS control module connector then re-run the test. More often than not the RABS controller is bad which causes the VSS signal to be pulled down.
Old 12-01-2012, 10:33 AM
Toplait's Avatar
Toplait Toplait is offline
Toplait is starting off with a positive reputation.
I have the same issue on my 92 F-150.
For me there is, "to much air space in between the Ring Gear and the VSS sensor and also worn // chips of metal taken out of the ring gear.
This could be caused by old age and also not shimming up the gears properly. I did 3:55 to 4:10 swap back in 2001 by my self at the age of 17. Since then I'v noticed some slop forming in rear-end when I accelerate and let off the gas. So it's almost time for a rebuild.
My New truck named BOB adforester 1999 to 2016 Super Duty 16 07-19-2010 12:51 PM
Am i the only one enjoying this??? Ryan50hrl General Automotive Discussion 74 03-14-2010 11:06 AM
gas guage and speedometer bob_mcbride5 1973 - 1979 F-100 & Larger F-Series Trucks 8 02-24-2003 01:44 AM
Speedometer - 78 Bronco astamp78 1978 - 1996 Big Bronco 2 01-21-2003 11:52 PM
Dancing Speedometer Anyone? Bogaski 1973 - 1979 F-100 & Larger F-Series Trucks 16 12-12-2001 03:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
