Upgrading Glow Plugs for 7.3
Old 11-30-2012, 11:30 AM
Luvmy7.3Ex's Avatar
Luvmy7.3Ex
Luvmy7.3Ex is offline
The Beast is slugglish to crank sometimes, it turns over but hesitates to start. I have 2 new OPTIMA Red Top batteries & a new starter. Was thinking about
up-grading OEM glow plugs & glow plug module to Diesel Rx ones. Has anyone ever used this brand of glow plugs & glow plug module? If so, how do they compare to OEM performance? Thx
Old 11-30-2012, 12:38 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Do NOT use anything other than OEM Motorcraft glow plugs.
Riffraff Diesel: Motorcraft Glowplugs ZD-11
There's no better glow plug. No such thing as an upgrade when it comes to GP's.
Determine why your Ex is sluggish. Don't just throw parts at it.
Stewart
PS - Where are you located?
Old 11-30-2012, 12:42 PM
Stewart_H's Avatar
Stewart_H
I just checked their website and don't even see where they offer Glow Plug Control Modules, just Glow Plug Relays. So unless you've modded your Ex to use GPR's, you're gonna have to stick with the GPCM.
Stewart
Old 11-30-2012, 05:36 PM
Luvmy7.3Ex's Avatar
Luvmy7.3Ex
Thanks Stewart_H, I will make sure I use OEM gp's for sure
Old 11-30-2012, 07:10 PM
F350-6's Avatar
F350-6
F350-6 is offline
If you're existing glow plug(s) are bad, you will get a check engine light and have a code stored. If you don't have a CEL, or a bunch of white smoke at start up, then replacing glow plugs won't solve your problem.
Old 12-26-2012, 03:55 PM
JumpinJoe's Avatar
JumpinJoe
JumpinJoe is offline
My the check engine light comes on and keeps coming back despite being cleared, so it looks like glow plug number 6 is at it again. Since I fixed the same problem 2 years ago with a used GPR, I figured it's time for the Guzzle GPR relay fix. Start my reading and it says that Exs and those with CA emissions can't do the mod - darn.
What to do next, I know, check FTE and search King of the SUVs because its an Ex specific 7.3 problem. The first search result heads me in the right direction:
Stewart
So, since I'm going with motorcraft all the way here, should I just replace the relay? Replace the cable to #6? Get someone to test the ohms on 6? Or, at 216K replace all 8 glow plugs (they've exceeded their useful lives)?
Old 12-26-2012, 03:59 PM
golfmedik's Avatar
golfmedik
golfmedik is offline
Stewart is right all the way. OEM glow plugs only! Just did mine when I put it wedges and re-ringed the injectors. Made a big difference. Didn't realize how tired they were
On EDIT: Take a look at your battery cables. I had to replace mine at 140K due to the cables corroding under the red covering. Mine had a similar problem that I thought was batteries. When I took the cable off, you could bend it and hear the copper fracturing on the inside. None of the corrosion could be seen. Again, buy only Ford cables if yours are doing this. It solved my problem.
Old 12-26-2012, 04:29 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by JumpinJoe
... Since I fixed the same problem 2 years ago with a used GPR
Are you sure? 7.3L Excursions use a Glow Plug Control Module (GPCM) not a Glow Plug Relay (GPR) unless of course the harness and PCM have been modified.
All 7.3L powered Excursions are compliant with California emissions. Unlike F250 and 350's with the 7.3L PSD, there is no California model.
Are you 100% sure you have a GPR?
Stewart
Old 12-26-2012, 06:31 PM
cameeks's Avatar
cameeks
cameeks is offline
I you go into the valve cover might as well replace them all. No point saving $30 on one side if you have to do it again.
Old 12-26-2012, 08:12 PM
Stewart_H's Avatar
Stewart_H
JJ, do you have a GPCM like in this pic...
Or a GPR like in this pic?
Stewart
Old 12-26-2012, 08:25 PM
F350-6's Avatar
F350-6
F350-6 is offline
A GPR can't set a code and tell you that #6 is bad. Stewart is right, if you replaced a relay, you replaced the AIH. Now it's time to fix the GPCM (or the wiring or #6 glow plug if it doesn't ohm out correctly)
Old 12-27-2012, 05:35 PM
JumpinJoe's Avatar
JumpinJoe
Confirmed, thanks to the pictures - I have a Glow Plug Control Module (GPCM) and a AIH Relay. Can't remember which one was replaced last time. But from the looks of it, I'd say the AIH is original to her. I'll start with that and work with it. Thanks Everyone.
Old 12-28-2012, 08:58 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Tried to rep you Stewart but I am in rep jail yet.
johnnyo53
43
03-12-2020 12:15 AM
1984_IH6.9_Project
12-27-2015 10:06 PM
3KP
16
07-27-2014 07:48 PM
Anatomy85
23
03-02-2004 01:26 PM
kellerkathleen
03-01-2003 12:55 PM
Quick Reply: Upgrading Glow Plugs for 7.3
