You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
The Beast is slugglish to crank sometimes, it turns over but hesitates to start. I have 2 new OPTIMA Red Top batteries & a new starter. Was thinking about
up-grading OEM glow plugs & glow plug module to Diesel Rx ones. Has anyone ever used this brand of glow plugs & glow plug module? If so, how do they compare to OEM performance? Thx
I just checked their website and don't even see where they offer Glow Plug Control Modules, just Glow Plug Relays. So unless you've modded your Ex to use GPR's, you're gonna have to stick with the GPCM.
Stewart
__________________ The Brotherhood of FTE <-click the link 1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft 1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff 2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes Never Fry Bacon NAKED!
Thanks Stewart_H, I will make sure I use OEM gp's for sure
If you're existing glow plug(s) are bad, you will get a check engine light and have a code stored. If you don't have a CEL, or a bunch of white smoke at start up, then replacing glow plugs won't solve your problem.
My the check engine light comes on and keeps coming back despite being cleared, so it looks like glow plug number 6 is at it again. Since I fixed the same problem 2 years ago with a used GPR, I figured it's time for the Guzzle GPR relay fix. Start my reading and it says that Exs and those with CA emissions can't do the mod - darn.
What to do next, I know, check FTE and search King of the SUVs because its an Ex specific 7.3 problem. The first search result heads me in the right direction:
Quote:
Originally Posted by Stewart_H
Do NOT use anything other than OEM Motorcraft glow plugs.
There's no better glow plug. No such thing as an upgrade when it comes to GP's.
Determine why your Ex is sluggish. Don't just throw parts at it.
Stewart
So, since I'm going with motorcraft all the way here, should I just replace the relay? Replace the cable to #6? Get someone to test the ohms on 6? Or, at 216K replace all 8 glow plugs (they've exceeded their useful lives)?
__________________
J.J.
2000 X 7.3 Limited 4x4
EBCs drilled/slotted, EBC Greenstuff, X/B Springs, Superchip, BilstienHDs and a Bully (brake-controller).
2001 X 7.3 Limited 4X4
Tekonsha Brake Control, Powerslot Cyros, Hawk LTSs, and Moogs
Stewart is right all the way. OEM glow plugs only! Just did mine when I put it wedges and re-ringed the injectors. Made a big difference. Didn't realize how tired they were
On EDIT: Take a look at your battery cables. I had to replace mine at 140K due to the cables corroding under the red covering. Mine had a similar problem that I thought was batteries. When I took the cable off, you could bend it and hear the copper fracturing on the inside. None of the corrosion could be seen. Again, buy only Ford cables if yours are doing this. It solved my problem.
__________________
Monty '01 Excursion Limited 4x4 7.3L, 187K, Diablo, AFE, Hellwig Sway bar, Procomp Shocks, Rancho RS5406 Stabilizer(bigger is better), V/B Spring Mod '10 F350 6.4L CC DRW 4x4 Edge CTS Monitor, Flo-Pro, Line-X, B&W Companion, Weathertech, Husky Guards, Viair 10007 Onboard Air System, Firestone Ride-Rites, Leer Top 2012 Sandpiper 365 SAQ weighing in at 15k
... Since I fixed the same problem 2 years ago with a used GPR
Are you sure? 7.3L Excursions use a Glow Plug Control Module (GPCM) not a Glow Plug Relay (GPR) unless of course the harness and PCM have been modified.
All 7.3L powered Excursions are compliant with California emissions. Unlike F250 and 350's with the 7.3L PSD, there is no California model.
Are you 100% sure you have a GPR?
Stewart
A GPR can't set a code and tell you that #6 is bad. Stewart is right, if you replaced a relay, you replaced the AIH. Now it's time to fix the GPCM (or the wiring or #6 glow plug if it doesn't ohm out correctly)
Confirmed, thanks to the pictures - I have a Glow Plug Control Module (GPCM) and a AIH Relay. Can't remember which one was replaced last time. But from the looks of it, I'd say the AIH is original to her. I'll start with that and work with it. Thanks Everyone.
__________________
J.J.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
