You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a 59 2wd swb f100 . Id love to make it 4wd . Is ther any frames out there that would be suitable for 4wd swap. I'm new to the whole frame swaps so I haven't a clue what would work and what won't.my main goal is to lift it and puts some biger tires on it possibly light duty ofroading . thanks for your help.
Are you asking about a frame swap because you want to go to newer running gear & powertrain? No experience with the 2wd's of this era, but aren't they leaf-sprung on the front end? Wouldn't it be easier to just have new front & rear springs built & buy a solid front axle and T-case(cases for these trucks were divorce-mounted anyway)?
__________________
1960 F250 4x4 - 292, 4spd, 16,000 ORIGINAL miles
2000 F350 Powerstroke CCLB 4x4 - Tuner, Intake, Exhaust, Gauges, leveled on 35's
1998 Cummins QCSB 4x4 - stock
Just swap the front ends it all just bolts right up. I did it to a 1960 f100 2wd. I got a 59 factory 4wd drive that had nothing worth saving but the running gear, so I swapped the front end into the 60. And it all just bolted right up.
No problem, but if u plan on running big tires like 33 or up and plan on "wheelin" it I wouldn't use the closed knuckle Dana 44 they ain't very strong and someone correct me if I'm wrong on any of this
Just to add to what 594x4 said. You could probably go for a little later model 4x4 as in 61-65 F100 series and get the job done too. I have not done this before so if that the route you can go make lots of measurements before getting involved on this suggestion. All the running gear looks very similar and I belive the frames are almost the same. Remeber you will need the cross member for the transfer case also. Thats pretty evident but thought I would mention it. 61-65 F100 will have the dana 44 front axle and they are leaf sprung. 66 F100 4x4 is based off the bronco front end has coil springs so would not be what you are looking for.
__________________
1965 F100 4x4 for fun. Name Gentelman Jim
1963 F250 4x4 for restore. Name Beast
1998 F150 4x4 for daily use. Name Birthday Boy
2001 Ford 4x4 Explorer Sport Trac (nice but sucks on MPG its underpowered)
Thanks for the tip. Can you guys give me a parts list of what I need to make the parts swap to the 4wd . Any thing would be helpfull I'm not that great at figuring out what I need .
There are a couple of complete (running gear wise) F100s (63-64) in a wrecking yard nearby. Unfortunately, there are a few miles between NY and ND!
__________________
I mine coal, therefore I proudly contribute to man-made warming (and lighting)...of your home, garage, shop, church, business, school, hospital, etc.
My other "car" is a 3 window coupe with a V12, a V8, 4wd, and a lockable diff!
I know seems like most of the good stuff left is west or south of here. I had a chance at a 60 f250 4wd bad every thing but the chassis eng and drivetrain . For 250. But I dident think about doing the swap till this past fall. That was last yr and has sense been scraped .
Any body that can help with the parts list for the swap it would be much appreciated .thanks
I have a 1960 F250 Big Back Window FACTORY 4X4 for sale. Complete minus engine (was a V8), radiator, and bed. EVERYTHING else is there and front and back glass are not cracked. Axles, driveshafts, trans, steering and everything else you can imagine are there.
I'm a long way from New York but close to Las Vegas if you wanted to figure out what it would cost to ship it. No, I won't part it out, sorry. If you're interested you can call me at 435-668-1401.
I wish I was a lot closer to you. If I wasent a few weeks away from unimployment I'd have no problem picking it up. Thanks for the offer anyway.
