advice on gearing change...equipped with fordomatic
I am planning on changing my rear end gears which are currently 3.92. I have the flathead and a fordomatic transmission. I am most wanting to cruise on the highway at 65-70. Right now my top speed is about 45-50. Any advice on which gears?
Ypu have come to the right place. In fact there is a new thread on this subject, and one respose even has a chart with RPM vs rear ratio based on 28" diameter tires. Here a link:
https://www.ford-trucks.com/forums/1...ar-change.html
I plan to keep the flathead and the fordomatic even if they both need to be rebuilt one day...both seem great right now though. I started this thread to be fordomatic specific. I figured most on here have a manual transmission so their gearing needs may be a lot different than mine. I was thinking of going with 3.08. I don't want it to be a complete dog though. Thanks.
I'd highly encourage you to measure your tires' rolling diameter as follows: with the truck on flat level concrete, make a mark at the bottom of the tire and on the concrete aligned with the tire mark. Roll the truck forward or backward until the tire mark is at the bottom again. Make another mark on the ground. Measure between the marks. Divide that measurement by 3.14. That is your rolling diameter. It can be very different from advertised diameter.
