Speed Density to Mass Air conversion - Ford Truck Enthusiasts Forums
Old 11-29-2012, 08:51 PM
Power of 8's Avatar
Power of 8 Power of 8 is offline
Power of 8 is starting off with a positive reputation.
I have a 91 F-250 with a 351W EFI, it has the stock computer with SD and as I look into putting in some upgrades I'm realizing that the SD is kinda restricting, especially when looking into cams, so I've been considering converting it to MAF with a kit like this F Series Mass Air Conversion Kits . My questions are has anyone put this, or something like it, in their truck? Does it help? Was there a noticeable power difference?
1991 Ford F-250 XLT Lariat regular cab 4x4, Mack Bulldog hood ornament and over sized aluminum wheels with BF Goodrich T/A tires. It has an almost stock 351W EFI, Hooker shorty headers, 3 inch stainless steel true dual exhaust with Flowmaster super 44s and 4 inch rActice polished stainless steel tips.
Old 11-29-2012, 10:01 PM
393STROKER's Avatar
393STROKER 393STROKER is offline
393STROKER is starting off with a positive reputation.
I have the one that Ford put out awhile back for the 5.0/5.8. I spliced the wires and re-routed the injector timing to the 351`s against Fords advice. They said that it didn`t make much of a difference because they switch on and off so fast,and that I probably would mess it up. But it doesn`t make sense to me to spray fuel with the valve closed. I did a pro job on the wires and it works real good.
Old 11-30-2012, 02:16 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
Maybe at drag race RPMS but on a street vehicle that's got to idle... these guys are idiots for suggesting that. I also have a Ford kit on my truck and yes the first thing I did was rewire it to match the engine, and guess what the idle is as smooth as glass. There have also been several others here over the years that have done their own conversions or used a kit with the wrong firing order and had severe idle problems and low power output.. all of which was fixed once the injector firing order was changed to match the engine.
As for the kit itself it won't make any difference in power on it's own, but put a cam in the motor or change the heads and exhaust and it'll work much better than it would with the stock computer.
Old 11-30-2012, 08:59 PM
Power of 8's Avatar
Thanks y'all
Fuel injection conversion SVTDriver97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 02-02-2015 01:52 PM
1993 f-250 Mass Air conversion boosted95 1987 - 1996 F150 & Larger F-Series Trucks 4 01-26-2011 01:07 PM
MASS Air conversion on a 92 F150 RIKIL 1987 - 1996 F150 & Larger F-Series Trucks 5 06-12-2010 09:18 PM
Mass air conversion- 1989 F250 BRay09 1987 - 1996 F150 & Larger F-Series Trucks 11 05-02-2010 03:39 PM
E04D Mass Conversion SmokeBlower Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 23 03-09-2010 04:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
