06 3.0 - Where would first point of failure be if ran out of oil - diagnosing what locked up - Ford Truck Enthusiasts Forums
Old 11-29-2012, 05:24 PM
Christof13T's Avatar
Christof13T Christof13T is offline
Christof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant future
so...
im not pointing any fingers..
but somebody fergot the old seal from the oil filter and ended up putting new filter on with old seal still stuck up there.
oil vomit marked the path of the post oil change test run for a good 100yds before it went dry.
less than 1/4 mile from driveway to locked motor.
motor since been unlocked by pulling plugs, and intake... dumping in oil... and starter bumped it free.
bolted everything back together and after it worked the oil out it fired right up.
smoked for 45 minutes or so light black stuff i assume from burning oil off in exhaust.
good power...
no real loss in economy that was noticeable...
but it has a significant tick going on.
heres the rub.
motor is already out.
was replaced 2 years ago almost.
so no vids unfortunately.
basically i figure the best head start i can get is ask you guys what you think.
worse case scenario a ring job eh?
Old 11-30-2012, 01:39 AM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
If it locked and then busted loose, that would be reminiscent of my old two stroke dirt bike seizing, then running after it cooled off. If that happened, you will have aluminum from your pistons on your cylinders, just like my old Suzuki did. And you'll have a perpetual oil burner.
I can't imagine the mains and cam bearings escaped injury.
IMO, a complete teardown is required.
Old 11-30-2012, 07:04 PM
cams are good. crank... not so much i think... will get that uncovered tomorrow.
oil looked like someone dumped silver glitter powder in it.
will be parting out everything that wasnt damaged. if you guys need anything hit me up.
ill post pics of the carnage and of goodies left over.
New Oil Pan & Pump......No Oil Pressure JimJr15 Ford Inline Six, 200, 250, 4.9L / 300 7 11-02-2015 04:33 PM
Oiling system upgrades/maintenance the_auto_tech 6.0L Power Stroke Diesel 10 01-20-2015 10:47 AM
ICP/IPR on start up mototrig 1999 - 2003 7.3L Power Stroke Diesel 4 11-05-2014 07:35 PM
Oil Leak from Oil filter on 5.4L Ford HELP PLEASE myhomerehab 1997 - 2003 F150 11 07-07-2013 09:10 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
