2000 Ford Ranger 3.0 v6 missing
Old 01-08-2013, 10:37 PM
Klindsey1990's Avatar
Klindsey1990
Klindsey1990 is offline
Hi folks, I'm new to this so forgive me if I don't give enough info. I've been having problems with my Ranger misfiring. It had blown the headgasket about a year and a half ago and I had it replaced. I now have around 126,000 miles on it and just before Christmas it started developing a miss. I put fuel injector cleaner in it, which seemed to help slightly but it came right back as I was driving home that night. It blew the number 3 plug out of the motor the next day, never had that happen before, ha. Anyway, me and my dad have changed plugs, plug wires, and coil pack, still the same problem. I don't want to keep pouring money into it and it doesn't fix the problem. It misses at an idle and the motor shakes. It runs, and it misses from the 50-65 mph range. If anyone has had this problem or ideas I would greatly appreciate it. Thanks!
Old 01-08-2013, 11:52 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Do you have any codes ? try to narrow it down to the missing cyl. Ck for proper fire , bad injector , burnt valve ,wiring issue ,ect . Do a compresson test to ck . cyl. health .
Old 01-15-2013, 01:28 PM
Klindsey1990
I had a diagnostic check on it today. Cylinder 3 and 5 were misfiring along with throttle control sensor bad. Replaced sensor and had computer reset. I've changed the plugs and wires about 6 months ago. Maybe got a bad set of plugs or wires??
Old 01-15-2013, 07:22 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Do you still have the miss ? if you only changed the tps , you probably do . Ck #3 and #5 plug . Also ck coil , plugs, and wires for carbon tracking . It does have one coil ,I think . #3 and #5 paired ? one can cause a code for both . Ck coil for cracks . Cracks will leak voltage and cause misfire . If not ignition look at fuel and compression .
Old 01-16-2013, 01:38 PM
Klindsey1990
Got the miss. changed 3 and 5 plugs and wires. So far so good.
Old 01-16-2013, 06:08 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
Good luck , hope you got it !
didij
1983 - 2012 Ranger & B-Series
16
01-25-2017 08:52 AM
david6036
01-08-2012 06:55 PM
benjamin.haynes
1997 - 2003 F150
10-12-2011 11:20 PM
mort13
01-18-2008 08:06 PM
ginna
09-24-2003 07:33 PM
Quick Reply: 2000 Ford Ranger 3.0 v6 missing
