Is there factory trailer wiring on 1994 F-250?
Old 08-28-2002, 03:44 PM
flyloki's Avatar
flyloki
flyloki is offline
I'm buying a '94 F-250 turbodiesel and I need to go pick it and my horse trailer up. It has a 6 pin (and no brake controller) and my trailer is 7 pin. I currently have a 7 pin and controller on my '88 f-250. Can I just cut the controller and 7 pin connector off my '88 and wire each to a flat 4 pin to plug into a factory type harness on the new truck?
Thanks,
John
Old 08-28-2002, 04:51 PM
Pastmaster's Avatar
Pastmaster
Pastmaster is offline
If you have trailer package, you should have a 7 wire connector at the back of the left frame modeling. If you know the wiring diagram, you should be able to just rewire your truck for your new wire plug.
'93 F-150 loaded and modified!
Check my Gallery
Old 08-28-2002, 06:26 PM
DeGideo's Avatar
DeGideo
DeGideo is offline
Brian Black
07-04-2017 06:07 PM
gapman789
05-16-2017 07:41 PM
medic868
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-06-2017 04:45 PM
Deanp88
2015 - 2020 F150
04-17-2017 10:41 AM
pastorjeep
09-20-2016 03:47 PM
Quick Reply: Is there factory trailer wiring on 1994 F-250?
