Go Back   Ford Truck Enthusiasts Forums > General > Projects
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
  #1 (permalink)
Old 11-29-2012, 01:39 PM
Pinhead-227 Pinhead-227 is offline
Garage is empty, add now
Pinhead-227 is starting off with a positive reputation.
'59 Ford C-600
I ran into an old ford cabover sitting in the weeds a few months ago and noticed it had nearly new front tires. I asked how much the owner wanted for the tires and he said $500 for the tires, $550 for the truck.
Needless to say, I bought the old jalopy.
I looked over everything and found that the original Y-block had been replaced with a 360 FE. The brakes worked and the motor ran so after a jump-start I drove the old beast home.
The first thing I noticed is the shifter was REALLY loose. When in gear the shifter could move in all directions at least 5 inches. That will have to be fixed. I also noticed that it pulls hard to the right. Upon closer examination I found that the right tire is further aft than the left tire by about 3/4-inch. Not sure how I'm going to resolve that.
The two-speed shift motor was froze up so i tore it down and cleaned the gunked-up lower bearing which made it shift like new.
It came without a bed so I've been looking around for a flatbed to throw on the old thing. In the interim, however, my dad and I welded up a gooseneck hitch so we can at least haul cattle and horses with the thing.
We decided to do some motor work so i got a used set of heads that had a valve job done and I massaged the heads with my Dremel to make the old combustion chamber design a little more efficient.
This pic shows our progress thus far:
Click the image to open in full size.
__________________
MPG Research: Come learn about fuel economy with us!
Quote:
The farmer is the only man in any economy that buys everything retail, sells everything wholesale, and pays shipping both ways.
  #2 (permalink)
Old 11-30-2012, 04:14 PM
Jexes23's Avatar
Jexes23 Jexes23 is offline
1978 Ford F-150
Jexes23 is starting off with a positive reputation.
Sweet. I love the old cabovers.
  #3 (permalink)
Old 11-30-2012, 06:29 PM
fordman75 fordman75 is offline
1996 Ford E250
My Garage
fordman75 has a good reputation on FTE.fordman75 has a good reputation on FTE.
Cool project!!
Those old cab overs are wicked.
__________________
Ted
1954 F100 4x4, 300, NP435/NP205
  #4 (permalink)
Old 12-04-2012, 12:30 AM
Rusty_Old_F250's Avatar
Rusty_Old_F250 Rusty_Old_F250 is offline
Rusty_Old_F250 is gaining momentum as a positive member of FTE.
Looking good! Glad to see that exhaust manifold I sent you getting some use.
Sam
__________________
1973 F250, 390 4spd 7500 lbs GVWR, known as "Grumpy" a name well earned
1992 Dodge D250, 12v Cummins, "Babe the Big Blue Ox"
next project: 1966 Mustang 200 3spd- sat for 15 years!
"Man does not control his own fate. The women in his life do that for him." - Groucho Marx
  #5 (permalink)
Old 12-05-2012, 01:38 PM
Quote:
Sam
Yep, works great!
It may not look like it in the picture, but the wheelbase of the truck is pretty close to the same as our '90 Extended Cab Ford F250. With where the hitch is mounted, the OAL of the truck and trailer is about 6" shorter than the F250 with the same trailer. The turning radius, though, is quite a bit shorter than the pickup!
Upon further investigation, we found that the front axle is bent about an inch rearward on the right side. That explains the pull to the right when going down the road. Now to find an axle... And figure out how to install power steering...
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
