Rust Preventative Undercoating... - Ford Truck Enthusiasts Forums
Massachusetts Chapter Join Chapter, Leader: donjamer
Old 11-29-2012, 09:05 AM
white-horse white-horse is offline
white-horse is starting off with a positive reputation.
I am trying to figure out what is the best way to prevent future corrosion and rust from showing up on my 1997 F-350 7.3 PSD. I have just removed the bed, sand-blasted and painted. Looks new under there. Now, what is the best "stuff" to spray under there to protect it all?? Should I get WD-40 in a 5 gal. drum and run it through a garden type pump sprayer, or a 5 gal. drum of hydrolic fluid (H. fluid is low cost) and run it through a compressor/spray gun? Or something else??? I figure I would run this through my local area since we have to deal with cold winters and lots of salt!! I hate salt on the roads!!!
Old 11-29-2012, 11:18 AM
donjamer's Avatar
donjamer donjamer is online now
donjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputation
Howdy White Horse
WD-40 would not be good.. It wears off easy..
When you painted did you use a good primer??
They have POR-15 that converts rust and is a good primer for frames..
I believe in Canada they oil the vehicles..
You could use old engine oil..
Never tried any myself
Old 11-29-2012, 03:50 PM
I did use a quality primer and paint, industrial grade. So its pretty protected for now. But I dont EVER want to see rust again. I just bought a heavy duty spray bottle and 1 gallon of wd-40 for only $16. Your right, it does wear off, but i'll hit it heavy once a month. However, every time they salt, I have to go to the spray wash and knock it off. Of course, that means another coat of wd-40. I have seen other stuff, amsoil makes something really good, but is EXPENSIVE! Eventually, i'll get a compressor and use the oil. Thanks!
Old 12-03-2012, 09:21 PM
Rose Clifford's Avatar
Rose Clifford Rose Clifford is offline
Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.
I'd never admit to spraying oil on my truck because I wouldn't doubt it's outside the boundaries of the EPA laws. However, I too have heard that it works really well. You could get a garden sprayer and put used motor oil in it and spray the bare metal parts that you couldnt paint. Water would bead right off and it would last much, much longer than WD-40. I bet it would last about one whole season if you did it right, ie when it's dry and ready to absorb liquid......
There are more eco friendly products such as Fluid Film that I've tried that work well. It lasts a while....but I doubt it works as well as oil.
Old 12-04-2012, 09:07 AM
I'm going to try the hydraulic fluid (5 gal. for $30 at tractor supply) and run it through a spray gun. Oil is a great idea. But I personally would not like to apply used dirty oil. But that's just me.
Old 01-01-2013, 12:00 PM
Thomas- Thomas- is offline
Thomas- is starting off with a positive reputation.
Old 01-02-2013, 08:04 AM
Do you think a garden sprayer would spray oil? Have you tried it?? I would rather use a garden sprayer than an expensive air compressor.
Old 01-02-2013, 12:27 PM
donjamer's Avatar
I don't see why it wouldn't..
Never tried it, but I know people who have used a sprayer for staining their deck..
Old 01-02-2013, 02:01 PM
I'll try it and post the results.
Old 04-20-2013, 12:19 PM
Ford 6.9 Diesel Ford 6.9 Diesel is offline
Ford 6.9 Diesel is starting off with a positive reputation.
Quote:
I have a 1984 F250 Diesel 6.9 truck since new and the very best way I found was my waste oil. Yup! Waste oil I paint the frame once a year and their is not a stitch of corrosion. I just replace the engine after 400000 miles and the bed was taken off for a crimped fuel vent line and the guys at the shop were speechless. Grab a brush!
Old 05-08-2013, 09:22 AM
BumpJr BumpJr is offline
BumpJr is starting off with a positive reputation.
I've actually known old timers who wipe the frames down with grease. It's last awhile and it shines. I shake my head at it but can't laugh because they have some stock old trucks with no rust or rot. They other thing they do is squirt mystery oil in the hard to reach areas and places where there are plugs like rockers and door jams
Old 07-24-2013, 05:21 PM
batchman batchman is offline
batchman is starting off with a positive reputation.
For spraying waste oil I believe the old timer recipe was to cut it 50/50 with kerosene. Need a place you can let it drip a while.
A fellow I know does a lot with old Unimogs and swears by the FluidFilm mentioned above.
Good luck,
- Jeff
Better Rust control, Better Bed supports droldsmorland 2017 Super Duty 18 10-26-2014 06:30 PM
Rust Prevention 61steven 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-22-2014 03:36 PM
question about fluid film application fordman19762003 1999 to 2016 Super Duty 6 10-13-2012 02:01 PM
Rust Prevention Olds69442 6.7L Power Stroke Diesel 19 06-20-2012 06:45 AM
55 gal. steel drum an "approved" container? busflyer General Diesel Discussion 5 10-31-2010 09:48 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
